specific directional wheel location?
Old Jun 29, 2012 | 12:46 PM
J W Drew's Avatar
J W Drew
Default specific directional wheel location?
My 85 Z51 has the rear right and the front left wheel fins pointed in the wrong direction. So, my thought is to take the car to the local tire dealer and have the wheels relocated. Nope! It appears that each wheel is designed for a specific location. They told me the offsets for the front and rear wheels are different. In fact, they showed me the stamp on the inside of the wheel that states the correct location. Is this correct? If so, it appears I will be shopping for two wheels.
Old Jun 29, 2012 | 01:04 PM
ghlkal's Avatar
ghlkal
2018 C4 of Year Finalist
Hmm ... I _thought_ that on a standard suspension 85 all the wheels were 8.5" wide while on the Z51 all the wheels were 9.5" wide. Perhaps the fronts are 8.5 while the rears are 9.5 - if that's the case, then yes you'd need two wheels. Although I don't know why you couldn't run 9.5" all around. I'm assuming you have a stock setup ...
Old Jun 29, 2012 | 01:52 PM
J W Drew's Avatar
J W Drew
The wheels are all 9.5". The short question is why can't you switch the front to the rear on the same side?
Old Jun 29, 2012 | 01:55 PM
Frizlefrak's Avatar
Frizlefrak
Measure them. Wider ones go on the rear of course. They may have been swapped to standard wheels somewhere along the line. If they're all the same, you can move them front to rear on the same side with no issues.
Old Jun 29, 2012 | 02:17 PM
QCVette's Avatar
QCVette
Active Streak: 90 Days
The base 85 had 16x8.5 front and rear.
The Z51 85 had 16x9.5 front and rear.
The only difference on the 4 Z51 wheels is left or right. So if you have one left side wrong and one right side wrong you can swap the two wheels and be done (If you don't have directional tires too. If you do you need to remount them correctly.)
Unless someone changed wheels and now has some 16x8.5 wheels on your Z51.
Note the 84 Z51 had 16x8.5 front and 16x9.5 rear. Therefore the 84 Z51 has a unique wheel for each location, but that combination can work if you happen to have that set of wheels correctly.
They should look like mine. 85 Z51
Old Jun 29, 2012 | 03:01 PM
WVZR-1's Avatar
WVZR-1
If they're a matched set - it wouldn't be an issue! You've been told they aren't!
QCVette's explanation is correct BUT I believe maybe your starting point needs to be identification of the wheels on the car. I would likely get all of the casting information from the back-sides and ID each wheel. Find out what you really have to work with!
Post the casting information for each and I'd think it easy enough to see what you need!
I'd think this the least aggravation to find out "what you got and what you need/want"!
And post a snapshot or two of the car as it sits presently!
Old Jun 29, 2012 | 03:07 PM
J W Drew's Avatar
J W Drew
In order to measure the wheels I would have to have the tires demounted. I can tell you the wheel that is currently mounted on the right rear is stamped "left rear only" and the wheel that is mounted on the left rear stamped is stamped "left rear only".
The directional fins on the right rear are wrong and the left front is wrong.
Thanks,
JW
Old Jun 29, 2012 | 03:12 PM
WVZR-1's Avatar
WVZR-1
In order to measure the wheels I would have to have the tires demounted. I can tell you the wheel that is currently mounted on the right rear is stamped "left rear only" and the wheel that is mounted on the left right is stamped is stamped "left rear only".
Thanks,
JW
You DO NOT NEED TO DISMOUNT ANYTHING - you're looking for information that is cast on the back-side of each wheel! Early MY wheels weren't location specific ONLY side specific.
Maybe you need to start with snapshot of the car as it sits!
Old Jun 29, 2012 | 04:18 PM
QCVette's Avatar
QCVette
Thanks,
JW
If the one on the right rear is stamped as a left rear, it sounds like it must be from a staggered set like the 84 Z51 since that is the only model that had these wheels in a unique location. I have not seen that stamping before, but I expect that it is a 16x9.5 and it can work fine as the left front. On cars with all 16x9.5's the wheels had the same offset front and rear.
Do you have information on the wheel that is on the left front? It sounds like that is a right side wheel, but from what you have said I can't tell if it is an 8.5 or 9.5 wheel.
Old Jun 29, 2012 | 05:18 PM
WVZR-1's Avatar
WVZR-1
I never realized the "stagger" '84MY BUT still to confirm the OP's fitment it seems wise to ID "all" wheels on the vehicle now. Correct?
An early SPO catalog does part # the '84MY rears as being the same as the '85MY which of course would be L & R -front/rear.
Here's maybe some casting info: FJ or FM LH wheels, FR or FK RH wheels. Seems easy enough to remove and confirm!
Old Jun 29, 2012 | 07:07 PM
Chuck Tribolet's Avatar
Chuck Tribolet
A tire shop will have a big set of calipers that can measure your wheel
width with the tire mounted.
Chuck
To specific directional wheel location?
