VATS decoder code ID?
Old Jul 22, 2012 | 04:57 AM
Cliff Harris's Avatar
Cliff Harris
The VATS module does two things: enable the starter relay and send a 30 Hz square wave to the ECM, which will then enable the injectors. You can buy bypass modules that will do these functions without reading the key pellet.
Reminds me... Many years ago I was at a Corvette event and I got in the car with a friend of mine with a '65 convertible (the top was down). He grabbed the ignition switch with his hand and started the car -- no key! I couldn't believe it and asked him if he wasn't worried about somebody stealing his car. His answer: "THEY don't know that it doesn't need a key".
Old Jul 22, 2012 | 08:17 PM
leesvet's Avatar
leesvet
[QUOTE=WVZR-1;1581369913]I researched further and Cliff's module that he ID'd as a 16045121 would be correct and possibly an original production number.
The progression seems to go 16045121 > 1227760 > 1228548. The 16080151 that the eBay auction references is also a part number that changes to a service number of 1228548 which is what the "seller" is selling.
What is the part # on the module that you've purchased?[/QUOTE]
The module that I bought is 16039969 with 8709 below that.
It was listed as 85 thru 89 IIRC which I though to be kinda iffy..but it was cheap and it was/is mine...
The board however, is completely different than the one in Cliffs photos.. so I will first see if the plug in is the same,. and if so, I'll read the resistor color codes and go from there...
if the plug is NOT the same I'll have a VATS module for a 19?? C4 for sale...
Old Jul 22, 2012 | 08:41 PM
WVZR-1's Avatar
WVZR-1
16039969 is a theft module that goes back to '81MY for Corvettes. It does early to later 80's Eldorado, Tornado, Riviera and some others. It seems there's an application for it as a theft module for '84 & 85 MY Corvettes as well as the '81 and '82 MY. It looks to have changed when VATS came along in '86MY.
I found an earlier part # for this module 16012660 that in 1983 $$$ was $180.00 from GM!
Yours should look like this: http://www.ebay.com/itm/Corvette-C4-...05%26rk%3D1%26
Old Jul 22, 2012 | 10:01 PM
leesvet's Avatar
leesvet
I have to tear mine apart this week so I'll get the part number off the original module and post that...right now its installed and dash is semi assembled but I'm pulling the cluster this week to do the complete repair from the bantee website...Once back in the dash I wil get that number. Had it written down somewhere but like most things on my desk its grown legs or has crawled under something. One of the mutant mosquitos may have carted off that sheet of note paper..I dunno. I'll get back to you in a day or two...I'm no where near done wth this until its fixed right. I DO appreciate your help and all the research. Thats the best part of this website...all the research thats done trying to help other people with their problems is like classroom if you pay attention.
Thanks for the help.
Old Jul 22, 2012 | 11:37 PM
Hooked on Vettes's Avatar
Hooked on Vettes
Originally Posted by leesvet
the board however, is completely different than the one in Cliffs photos.. so I will first see if the plug in is the same,. and if so, I'll read the resistor color codes and go from there...
Here's a picture that was posted by Rich B. that shows
the Alarm module and the Decoder module.
The modules are contained in the same style plastic case.
You can see there is a difference in the circuit board edge connector
fingers.
Old Jul 23, 2012 | 01:22 AM
Cliff Harris
The VATS (Vehicle Anti Theft System) module is the one that reads the pellet in the key and enables the starter relay and injectors through the ECM.
The other module is a TDS (Theft Deterrent System). It is controlled by locking/unlocking the doors and honks the horn if a door is opened without disarming it.
Old Jul 23, 2012 | 03:51 AM
WVZR-1's Avatar
WVZR-1
Actually using a different resource the 16039969 has applications for Corvettes through '89 model year. Are both of these present on '86 - '89MY cars? Likely?
Not having a FSM for any of the model years it would be difficult for me to confirm. Perhaps someone with years '86 - '89 could confirm it's use and also the location!
This thread and his problem/symptoms might be a confirmation of there actually being "both" present in '86 - 89MY and how easily it is to confuse the two:
http://forums.corvetteforum.com/c4-t...post1581381989
Old Jul 23, 2012 | 09:06 AM
oldalaskaman's Avatar
oldalaskaman
Thanks..
I've read what the FSM has to say and it tells you to use the interrogator to find the code of a replacement module while installed...
The process is basically trial & error. Try code 1 then wait 4 min then try code 2 and so on...
IF I can find the tables (charts) that show the resistor values for each code then I'll invest $8 in resistors and do the trial & error method at home. Then I can take that info and have a new key cut thats the correct code and fits my lock cyl.
I'll ask the question anyway...and make a few calls monday.
If someone has that chart thats used for making a VATS key bypass, I'd sure like to have a copy !
http://www.ebay.com/itm/Directed-Ele...item3cc8bce3de
Hey Lee, I used this, works great to find out the resistance key you need
Old Jul 23, 2012 | 02:15 PM
WVZR-1's Avatar
WVZR-1
You've promoted this auction a couple times in "this thread"! I'm sorry I just don't see the significant value of the "buy"! The "total" buy is $25! I've missed what?
Old Jul 23, 2012 | 07:19 PM
oldalaskaman
wvzr1, not selling any thing , it just worked to find the key value, dont know what else you're talking bout. not suggesting anything to you, just tryin to help the op without all the buy all these extra tools and parts mess... $25?? in that fleabay ad its $9 with a little research its $4. mabye you should concentrate on the ops issue instead of this non helpfull nauseating dribble.
Old Aug 16, 2012 | 01:19 PM
gudawuda's Avatar
gudawuda
Default Vats
I have a module option 12, and a Vats Interrogator --$175.00 shipped US.
http://i1087.photobucket.com/albums/...d/IMG_1932.jpg
Eventually will post these on ebay, ran across this thread and figured maybe this could help...
Old Aug 16, 2012 | 02:35 PM
Ray Quayle's Avatar
Ray Quayle
- 1986 Original Owner -
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In VII Veteran
You have a PM.
Old Aug 16, 2012 | 04:42 PM
  #33
leesvet's Avatar
leesvet
I appreciate the offer but I think I'll just go thru the motions this time of learning the module code, then hope its another 20 yrs before this replacement fails...I need to address this issue before the original fails and leaves me walking. The thing ( I think its the module) has thrown a inj shut down at start up once or twice. Key issue maybe...but I still need to address the faulty module asap.
Too many projects on the "list". Hard to prioritize sometimes.
Does make me wonder where all the VATS interrogators went as they were phased out of service? lost in a box in somebodies attic perhaps? Lots of outdated tools and equipment up there...
Old Aug 16, 2012 | 04:46 PM
  #34
leesvet's Avatar
leesvet
fingers.
Well..S*** !
I did not see this until now...
its painfully obvious that I have an alarm module, not another decoder.
Its back to the drawing board.
Old Sep 1, 2012 | 09:41 PM
  #35
kitttransam's Avatar
kitttransam
I measured my vats key. I got a reading of 4.70 , would that be an option 1 key or am I getting a bad reading?
Old Sep 2, 2012 | 12:20 AM
  #36
Cliff Harris
4.70 would be #11 according to:
http://www.joestradingpost.com/vats/89_passkey.htm
If you measure on the 20K range you have to multiply by 1000 to get ohms (K = 1000). 4.70K = 4700 ohms
Old Sep 18, 2012 | 06:43 PM
  #37
leesvet's Avatar
leesvet
Going back to this...
does anyone have an idea where the alarm module is mounted?
I cannot find one in my car although something is there to manage the alarm/noise maker. My Decoder module is under the breadbox as described.. I see a smaller module behind the fuse panel that might be the '87 version of the alarm module. The wire colors are right but its 1/2 the size of the module in the photo...
To VATS decoder code ID?
Old Sep 18, 2012 | 09:29 PM
  #38
Dans 85's Avatar
Dans 85
Leesvet,
There is a much simpler way and it will only cost you $1.
Forget about the interrogating the module. Measure the resistance of the diode pellet in your current ignition key. Get a resistor to match that (within 2% will work fine) and swap out the reference resistor on the board of the decoder module. This will save you the cost of getting new keys.
Old Sep 19, 2012 | 01:46 PM
  #39
leesvet's Avatar
leesvet
Originally Posted by Dans 85
Leesvet,
Thanks for the suggestion but that doesn't help a failing decoder module......
I'm well past resistors.
Old Sep 19, 2012 | 03:05 PM
  #40
WVZR-1's Avatar
WVZR-1
I thought the "alarm module" was behind the actual right side IP like this:
