MAJOR COOLANT PROBLEMS
Old May 26, 2002 | 02:29 PM
Ender85's Avatar
Ender85
Default MAJOR COOLANT PROBLEMS
Ok, so I did everything according to the Haynes manual. At the end, when I was to turn the car on and let it idle, I did - until coolant temp got to 230 F. At this point I turned the car off. As I did this, I heard a bubbling noise, and then coolant just kind of poured out of the bottom of the car. :confused:
I have no idea what happened...now I have a puddle of coolant on the ground in my garage, and no idea what to do...
Old May 26, 2002 | 02:55 PM
jfb's Avatar
jfb
Default Re: MAJOR COOLANT PROBLEMS (marthpodi)
Clean the mess up. Try to find out where the coolant came from. Coolant should not come out anywhere at 230F nor after the engine is turned off. You have a hose that leaked or the overflow bottle overflowed. Start looking.
Old May 26, 2002 | 03:09 PM
Ender85's Avatar
Ender85
Default Re: MAJOR COOLANT PROBLEMS (jfb)
got it: Overflow bottle overflowed...gah. Ok, got it. I must have put a little too much coolant in. Anyway, now that the level is at normal (I hope) What do I do about the coolant temp getting so high...?
Old May 26, 2002 | 03:17 PM
Wasemiller's Avatar
Wasemiller
Hey, check your fuse - Ours continued to do the same thing (also our fan wasn't coming on to cool the car down and the temp kept rising) come to find out our fan fuse was blown. :confused:
Just an idea. :seeya
Old May 26, 2002 | 03:19 PM
Ender85's Avatar
Ender85
Default Re: MAJOR COOLANT PROBLEMS (Wasemiller)
I don't think thats the problem - the fan came on at 226 as it was supposed to when I turned the AC on and off.
Old May 26, 2002 | 03:42 PM
greenvette95's Avatar
greenvette95
St. Jude Donor '03
Mine would overheat (240) and my problem was a #1 bad rad cap and #2 the radiator cap was the wrong lbs pressure. I got a new correct pres cap and everything is good.. I hope this helps. :flag
Old May 26, 2002 | 03:51 PM
vader86's Avatar
vader86
Default Re: MAJOR COOLANT PROBLEMS (Whitevette91)
If you let it idle its gonna get to 230 no matter what. Did you clean off the front of the radiator? what about a new thermostat?
Old May 26, 2002 | 05:33 PM
93 ragtop's Avatar
93 ragtop
did you get the air out of the system?
Old May 26, 2002 | 08:49 PM
Ender85's Avatar
Ender85
Default Re: MAJOR COOLANT PROBLEMS (Red 86 4+3)
what do you mean get the air out of the system?
Old May 26, 2002 | 11:02 PM
cohocarl's Avatar
cohocarl
Ok, so I did everything according to the Haynes manual...
What had you done according to the Haynes manual?
Old May 26, 2002 | 11:25 PM
Ender85's Avatar
Ender85
Default Re: MAJOR COOLANT PROBLEMS (cohocarl)
Drained the coolant, drained the reservoir, flushed the radiator with hose water, refilled the radiator with 50/50 water/antifreeze and restarted the engine.
Old May 26, 2002 | 11:30 PM
vader86's Avatar
vader86
youre supposed to let the car run, with radiator cap not installed, until the tstat opens and the coolant makes its way through the system and all the air bubbles make their way out
Old May 27, 2002 | 12:14 AM
Ender85's Avatar
Ender85
Default Re: MAJOR COOLANT PROBLEMS (vader86)
hrm...well that was the bubbling sound then - doh. :bb
What do I do to fix that?
Old May 27, 2002 | 12:17 AM
Ender85's Avatar
Ender85
Also, I used tap water, not distilled/deionized - how much of a difference will this make? Do I need to do it again, this time with distilled water??
:cry
Old May 27, 2002 | 07:54 AM
93 ragtop's Avatar
93 ragtop
:cry
I dont think that the distilled water would affect the cooling ability, it has more to do with the coolant system not corroding as quickly. But after it is cool take the cap off, start it up and let it run till it starts to get to about 200 degrees, make sure you add water to it and this will eliminate most of the air. Also, you can crack the bleeders located on top of the t-stat housing and the throttle body to remove any small amounts of air. Its not a bad idea to buy a new cap, they are cheap insurance, and if it is weak it will allow it to boil over. One other caution, when bleeding it through the bleeders, try not to get any on the opti-spark. Slide a piece of vacuum line on the bleeder and run it to a bucket. Good luck.
Old May 27, 2002 | 10:10 AM
Sam Lam's Avatar
Sam Lam
In reference to the "air purging problem" when flushing and refilling, I learned a trick some time ago. Take out the thermostat and drill a 1/16 (.0625) inch hole in the thermostat. The location of the hole is critical!!! The hole should NOT be put in the part of the thermostat that moves. Instead, it shoud be placed in the area between the center hole and the thermostat outer diameter. When you refill the system, this "little hole" will allow the air to escape and refilling is very easy. The little hole does not change the engine warm up time. If anyone needs a picture of this, please email me. Regards, Sam
Old May 27, 2002 | 10:33 AM
ittlfly's Avatar
ittlfly
Default Re: MAJOR COOLANT PROBLEMS (Sam Lam)
It sounds like a thermo. and / or air in the system. Be sure to bleed the system by use of the 2 bleeder screws until the coolant runs without bubbles. Replacing the thermo. and cap is a good idea too. :yesnod:
To MAJOR COOLANT PROBLEMS
Old May 27, 2002 | 11:47 AM
Ender85's Avatar
Ender85
Default Re: MAJOR COOLANT PROBLEMS (ittlfly)
Where are the two bleeder screws? I have an '89 so no Opti-spark
Old May 27, 2002 | 11:59 AM
hotwilzz's Avatar
hotwilzz
your 89 does not have bleeder screws. the tip on drilling a hole in the t-stat is a good one and also you can, as you are refilling the system pour coolant directly into the intake before attaching the upper hose and this will help purge air out of the system. do this, wait a couple of minutes and repeat until the block won't take any more, then attach you hose and fill the rest of the system
good luck
david
Old May 28, 2002 | 06:27 AM
93 ragtop's Avatar
93 ragtop
If you have the car back together, then let it cool down completly, take the cap off, and start it up. Let it idle, and add a little coolant until you see it is about 2-3 inches below the top of the radiator. Now wait until it heats up, about 190-200 degrees, and the upper hose should be getting hot, indicitating flow, and then continue filling the system until full. Replace your cap. It should be ok at this point, however, I would check coolant level the next morning to confirm it is full. The purpose of doing this is the t-stat, when closed will lock a pocket of air in the engine, and once it heats up, and the t-stat opens, it will purge the air out, and of course you will need additional coolant in the system. Good luck
