Can I remove this stuff?
Old May 26, 2002 | 04:10 PM
85WHITEZ51's Avatar
85WHITEZ51
Default Can I remove this stuff?
My smog pump went out so I thought I would just gut it because I can't afford an eliminator kit right now. Do you need all that smog stuff if you don't have the smog pump working or can you just remove it all? I was curious as it had two electrical connectors going to it and was worried it wouldn't run right without it or throw a code. Thanks.
All the black stuff associated with the smog pump in the pic is what I am talking about.
Old May 26, 2002 | 07:20 PM
Rob90's Avatar
Rob90
Default Re: Can I remove this stuff? (85WHITEZ51)
You can trash all of it. The air divert valve and hoses. You should not throw a code. I have had mine off for more than a year with no probs. You will also need some pipe ends to thread onto the check valve once the hose is removed. I thought you guys had the smog police in TX. Dont know if you will pass visual inspection with all the stuff gone
Old May 26, 2002 | 07:36 PM
Sharky Guam's Avatar
Sharky Guam
Default Re: Can I remove this stuff? (Rob90)
I threw mine out in the 86 with good results. No codes.
:cool:
Old May 26, 2002 | 07:46 PM
VetteNoob's Avatar
VetteNoob
Dont worry about the visual inspection. Ill get you hooked up. Im gonna yank all of mine when we do the AC next week.
Old May 27, 2002 | 03:30 AM
85WHITEZ51's Avatar
85WHITEZ51
Default Re: Can I remove this stuff? (VetteNoob)
Inspection isn't a problem as vettenoob can help and I have a place here that will give me the sticker by only looking to see if my lights work. I have yet to have someone open my hood. Heck, my friend went open header there in his mustang and got passed.
To Can I remove this stuff?
