fuse
Old Jul 2, 2012 | 10:04 PM
andalusianlove's Avatar
andalusianlove
1st Gear
Default fuse
I recenty bought a 1989 n have replaced the alt n battery. Just drove it 2 miles n it had over 14 amps. Now it won't turn over nothing no lights, heat, nothen. Stuck
Old Jul 2, 2012 | 11:19 PM
HlhnEast's Avatar
HlhnEast
Are your battery terminals clean and tight? Especially if they are not factory style terminals. The cheapie bolt on terminals have caused me tons of grief. First place I go if my car wont charge or start.
Old Jul 3, 2012 | 02:07 AM
Cliff Harris's Avatar
Cliff Harris
It sounds like a bad connection on one of your battery cables. Don't forget that those cables have two ends and both ends have to have a good connection or you're dead.
The negative battery cable connects to a bolt on the side of the block above the oil filter.
The positive battery cable connects to the starter.
14 amps? I doubt it. I think you meant 14 VOLTS.
To fuse
