Holley AFPR
Old May 26, 2002 | 07:19 PM
chucks88's Avatar
chucks88
Default Holley AFPR
I figure I would snap off a couple of pics before it gets burried under the plenum and runners.
Are there any tricks to keep my photos from blurring/getting bit mappy when I reduce them. They start off at 1600x1200 pixels from my camera. I usually reduce them down to 600x450 before I post them. and often times, like these photos, they get blurry.
Old May 26, 2002 | 07:32 PM
Rob90's Avatar
Rob90
Default Re: Holley AFPR (chucks88)
Sweet piece. Where do you adjust the FP. I have a big nut on mine to twist
Old May 26, 2002 | 07:34 PM
Sharky Guam's Avatar
Sharky Guam
Default Re: Holley AFPR (Rob90)
Actually, those pics are not too bad. :cool:
Old May 26, 2002 | 07:41 PM
chucks88's Avatar
chucks88
The top disc turns. Like a thumb screw but a little bigger.
Old May 26, 2002 | 07:43 PM
Rob90's Avatar
Rob90
Thats they way it looked to me but I wanted to be sure. I would like to get that piece because I have a lot of polished pieces on my car.
Old May 26, 2002 | 08:04 PM
Red91Vette's Avatar
Red91Vette
another great feature of the Holley peice is that it comes with a new rubber gasket. no other AFPR does this
Old May 26, 2002 | 08:07 PM
scorp508's Avatar
scorp508
I may purchase that one to replace the one on my car to get the new diaphram. I need to figure out if I have enough space with the superram on to get it off w/o removing the plenum. :)
Old May 26, 2002 | 09:05 PM
h rocks's Avatar
h rocks
Default Re: (scorp508)
The others are all cr*$. I've wasted more money on the others before I found the Holley unit three years ago. It's a totally new unit. Spring, diaphram, housing, the whole nine yards. Best thing is, you don't need to fiddle around with a tiny ignition wrench to adjust it. The whole top of the regulator IS the adjuster. Nice piece. Thanks for taking a picture of it. I've tried for years to describe it to other Forum members.
Old May 26, 2002 | 10:45 PM
cohocarl's Avatar
cohocarl
Your photos look good to me also!. It depends on what photo editing program you are using, but most will have a setting to adjust the resolution when you resize and save it. Some will let you adjust the D.P.I., or high, medium or low quality. I try to keep my pics as small of file size as possible (for those who are bandwidth challenged), but still keep it looking decent.
The Holley afpr looks great, especially if you've polished the plenum & fuel rails. It's alot more durable than others from what I've read.
I had rounded off some of the "tamper proof" torx screws when I was playing around with trying to make my own afpr, so I went with some new allen head screws. The screw size & a pic of my Holley afpr is on this link: http://forums.corvetteforum.com/zerothread?id=159466
Carl
Old May 26, 2002 | 10:52 PM
LT4Mike's Avatar
LT4Mike
I just put a Holley AFPR and a Holley TB on my LT4. I show my car most of the time and these Holley pieces are nice and shiney.
Old May 27, 2002 | 04:00 AM
chucks88's Avatar
chucks88
Default Re: Holley AFPR (cohocarl)
I rounded off some of the "tamper proof" torx screws when I was playing around with trying to make my own afpr, so I went with some new allen head screws. The screw size & a pic of my Holley afpr is on this link: http://forums.corvetteforum.com/zerothread?id=159466
Carl
KOHO (It's a hockey thing),
Your photo and description in that thread was the impetus behind my getting the Holley AFPR.
Thank-you
Chuck
Old May 27, 2002 | 04:12 AM
RonRed89's Avatar
RonRed89
Scorp,
Let me know your results with space clearance. I may need the regulator soon myself.
Old May 27, 2002 | 03:01 PM
Guest
Guest
Posts: n/a
Default Re: (RonRed89)
I have taken the AFPR off with the SR plenum and runners in-place, it's no problem unless you loose hardware under the plenum. :lol:
To Holley AFPR
