strange air conditioning issue
Old Jul 4, 2012 | 02:19 PM
therbst's Avatar
therbst
Default strange air conditioning issue
I have a 95 LT1 auto. This morning for the first time living in WI. I turned on the A/C...... everything was fine while at idle, cold air began coming out so at that moment things looked good. Then I put the car in Reverse and the motor began missing badly. So I put it back into Neutral and the idle went back to perfect. So again, while in Neutral the car idled fine and cold air came out. I put it into "Drive" and the idle began to miss again. I've fixed multiple issue with bad idles before ( I changed out my opti, new sensors, cleaned throttle body etc.....) but never have i heard or experienced the engine missing badly only while the A/C was on and in gear and then perfect idle and cold air while in neutral. Any suggestions would be appreciated.
Old Jul 4, 2012 | 05:07 PM
1fatcat's Avatar
1fatcat
Just a suggestion, the throttle position sensor is sensitive! Don't over tighten the screws! Over tightened screws can warp the sensor and cause skewed readings.
Old Jul 4, 2012 | 07:37 PM
93Rubie's Avatar
93Rubie
Can you turn the A/C compressor (center of pulley) by hand with minimal resistance?
If the IAC is not opening up more, in Drive with A/C on this will cause stumbling. The A/C compressor is quite a load for a idling engine.
Does it miss if you engage the A/C at cruising speeds?
Old Jul 4, 2012 | 09:14 PM
therbst's Avatar
therbst
Originally Posted by 93Rubie
Can you turn the A/C compressor (center of pulley) by hand with minimal resistance? Yes it does turn pretty easy.
No nothing that I can feel. I tried it again and you can definitely feel the load on the engine when it first kicks in but this is a different kind of stumble. Thanks again for the suggestions
Old Jul 4, 2012 | 09:41 PM
VetteMed's Avatar
VetteMed
Take out your Idle Air Control motor, and clean it and the passages in the throttle body.
Old Jul 4, 2012 | 09:43 PM
therbst's Avatar
therbst
I apologize for not stating earlier. The IAC and the TPS are new and the TB was removed and cleaned
Old Jul 5, 2012 | 01:22 PM
SunCr's Avatar
SunCr
Probably help to scan in capture mode - you want to look at the A/C request; Park/Neutral or Gear signal; IAC counts; Targeted and Actual Idle and then Voltage. I'd guess that a bad Clutch Coil could be zapping the life out of the electrical or a funky gear signal would mean it's correcting for compressor loading but not Drive/Reverse or it's got the Gear, but not the A/C request, and any of this could be a bad ECM. Scanning it would narrow it down.
Old Jul 5, 2012 | 11:02 PM
93Rubie's Avatar
93Rubie
100%, that is if you have a scan tool.
Seems a lot of folks like to think you can fix computer controlled vehicles without info (FSM's) or some sort of scan tool/software.
OP: Beg borrow one to do this. It will help big time!!!
To strange air conditioning issue
