blew up LT-4
Old Jul 6, 2012 | 06:04 PM
firstlt4's Avatar
firstlt4
Cruising
Default blew up LT-4
can anyone help? LT-4 motor recently broke in bottom end, connecting rod sticking out oil pan, I'm sure other stuff broke inside, not sure if heads are okay but I am sure the block is not. was trying to find a used LT-4,,, ha ha,,, found one for about 3k, just wondering what options are there,,,, was looking at finding cheaper LT-1 and putting heads on it, what about computer issues then? also thought about LS-1 swap but doesn't seem to easy with mounts, computer, etc.? I'm a back yard mechanic (lol) and was hoping to do this the easiest way possible, like everyone else I don't have a lot of money or time, maybe I should just sell it like it is but the car has some sentimental meaning. I'm distressed, can anyone help?
Old Jul 6, 2012 | 06:11 PM
leesvet's Avatar
leesvet
well,
my sympathies on the dead LT. Its painful to relive the trauma whenever you look at the rod sticking out the bottom....
To find a good used block search Craigslist in your town. Might try FleaBay but what you find will usually be halfway cross the country...but there ARE blocks & whole motors there at reasonable prices.
As long as you stick another LT in there with the same heads and sensors the computer won;t know the difference. Its what the sensors see is what matters..As long as the engine is the same as the last one its ok.
Old Jul 6, 2012 | 07:57 PM
96GS#007's Avatar
96GS#007
Other than the sensors, manifolds, accessories, front cover, and the intake, the key components (block, crank, rods, pistons) are toast. With a failure like that, it's nearly inconceivable the cylinder heads didn't see some contact as well. At a minimum they will need to be checked ($300). Most likely one or both need to be re-worked or outright replaced ($1,000 for a ready to bolt on (but used) pair of LT4 heads).
You're cheapest alternative is to find a running '96 Corvette LT1 engine. A simple reflash of the PCM and you'll be good to go. You *might* be able to find one for ~$1500 but I'll bet you'll be closer to $2000. Generally people sell the engine with the PCM, so that will save you the cost of the PCM reflash.
Frankly $3k for a good running used LT4 isn't bad if it comes with everything including the accessories, wiring harness, and the PCM.
Old Jul 6, 2012 | 08:07 PM
93Rubie's Avatar
93Rubie
I have to know, how did this happen?
Old Jul 6, 2012 | 09:03 PM
firstlt4's Avatar
firstlt4
Cruising
well, high speed driving school wasn't favorable this year, the car was really running great, passing everyone,,,, until I was doing 135 at 6000rpm and boooommmm..... talk about smoke, my brother in law said there were flames coming out the back about 20'... wish I at least had that on video.
QUOTE:: You're cheapest alternative is to find a running '96 Corvette LT1 engine. A simple reflash of the PCM and you'll be good to go. You *might* be able to find one for ~$1500 but I'll bet you'll be closer to $2000. Generally people sell the engine with the PCM, so that will save you the cost of the PCM reflash.
Thanks for the input.... so best bet is probably just putting an LT-1 in... get the LT-1 motor, PCM, wire harness,,,, and it should all just basically be plug and play?? with any luck finding one from a 96 that's probably the way to go...
the LT-4 I was looking at was just complete motor, no pcm or harness.
Old Jul 6, 2012 | 09:14 PM
cv67's Avatar
cv67
St. Jude Donor '05
You already got the harness etc all you needs the motor
Very very lucky you didnt eat it with all that oil spilling out .
Old Jul 6, 2012 | 09:50 PM
merim123's Avatar
merim123
any lt1 5.7 shortblock will work, from a fbody or corvette. you should be able to get a decent shortblock for less than 1k (assuming your heads are ok).
Old Jul 6, 2012 | 10:58 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
Why can't the OP use a basic LT1 short block and install his LT4 top end and cam, then maintain his current harness, PCM, etc.?
Old Jul 7, 2012 | 12:22 AM
bjankuski's Avatar
bjankuski
He can. The lt1 block and lt4 block are the same.
Old Jul 7, 2012 | 02:13 AM
merim123's Avatar
merim123
^^^that was my point, lt4 vs lt1 is a top end thing not a shortblock difference
Old Jul 7, 2012 | 09:28 AM
RichS's Avatar
RichS
Out of curiosity were you at Pocono with a instructor named Allen?
Get a LT1 short block to rebuild and use your LT4 cam and heads.
Old Jul 7, 2012 | 03:56 PM
dizwiz24's Avatar
dizwiz24
I know you are looking ahead, but let's look back at what caused this.
If the situation that caused this is not corrected, it could possibly happen again..
Oil system?
Fuel system?
Bad pcm? Or spark control?
How many miles on it?
Any mods?
Can you share with us what caused this?
I've been on this forum 10+ years and catastrophic bottom end failures are rare.
Old Jul 7, 2012 | 05:58 PM
93Rubie's Avatar
93Rubie
They always run the best right before they blow up. Crazy.
I assume you maintained this engine properly?
Old Jul 7, 2012 | 06:07 PM
Docderek05's Avatar
Docderek05
I am sorry brother..sounds like a painful experience...good luck with finding a replacement..I hope you are back on the road real soon....
Old Jul 7, 2012 | 06:19 PM
Docderek05's Avatar
Docderek05
http://boston.craigslist.org/nos/pts/3123376318.html
Maybe what the doctor ordered..?
Old Jul 7, 2012 | 10:48 PM
96GS#007's Avatar
96GS#007
He can....but how many times do rods exit the engine and there not be any cylinder head damage?
Step one...tear it all down
Step two...have the heads looked at
Step three...figure out what needs to be bought.
Old Jul 7, 2012 | 10:58 PM
PLRX's Avatar
PLRX
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09 thru '20
Ouch, I'm with Jim. Those heads got to be toasted.
Damn, you were hauling on 4th gear, too bad you could not keep going. Good luck on finding a new engine.
To blew up LT-4
Old Jul 7, 2012 | 11:14 PM
kimmer's Avatar
kimmer
C4 of the Year Finalist
You can do wonders with duct tape.
Old Jul 7, 2012 | 11:19 PM
cv67's Avatar
cv67
St. Jude Donor '05
That motor probably has shrapnel everywhere in it up to the TB.
If the heads were intact he should buy a lotto ticket. They maaay be repairable though. Sometimes worth it sometimes not.
Old Jul 8, 2012 | 07:48 AM
LannyL81's Avatar
LannyL81
The LT4 has a different crank than the LT1....a different GM part number anyways...along with all the top end stuff. Not sure about the pistons/rings/rods.
There is a chart somewhere on the web that lists all the differences between an LT1 and LT4.....now where did I see this at????????????
