90 Coupe idle issues
Old Jul 6, 2012 | 09:37 PM
CRUZNC4's Avatar
CRUZNC4
2022 C4 of the Year Finalist - Unmodified
Default 90 Coupe idle issues
I've been having a hesitation/miss/idle issues and it's been getting worse. I replaced the fuel filter about two months ago and helped a little and replaced the spark plugs last weekend and helped a little. I was thinking a bad plug wire, but I'm suspecting the egr valve could be sticking. The car has 45k and is not a daily driver. Any comments are appreciated.
Old Jul 7, 2012 | 01:55 AM
pkazsr's Avatar
pkazsr
Cruise-In X Veteran
St. Jude Donor '09
If you are going to wrench on it yourself you need a FSM. What you did so far is OK but it looks like you are heading to just throw parts at it until it is fixed.
Because it is easy and cheap, I would suggest visually checking the cap and rotor. Carbon tracking or burned contacts will cause your problems.
Old Jul 7, 2012 | 07:06 AM
joe paco's Avatar
joe paco
if the problem is only at idle, runs fine otherwise, that probably eliminates some things, like injectors, fuel pressures, etc..
some easy things are cleaning throttle body with tb cleaner, whatever, a clean rag or brush. no need to remove it. also ck TPS, throttle position sensor. yours is not adjustable, I think, but is a possibiity, since it controls fuel signals.
if it starts fine probably not tps. "sounds like" ignition problem, maybe a plug that has insulator cracked, wires leaking, etc. should have seen evidence with plug colors when you changed them.
clean inside dist cap, check for cracked cap, etc. rotor is cheap but rarely is a problem. if base timing is retarded, it can cause hesitation but not the miss, probaby not rough idle.
if MAP sensor -manifold absolute pressure- is part of the issue, it would also cause hesitatioin. you can unplug the tps, run it to see the reaction. plug in, then unplug map, same thing. this will set a code. if you have not checked for codes or don't know how, I can point you to some instructions, or others will.
joe
Old Jul 7, 2012 | 10:17 AM
Red89'-L98's Avatar
Red89'-L98
FL Events Coordinator
St. Jude Donor'13
I would try new spark plug wires and distributor cap and rotor just fixed my idle issue with it and it starts a lot better.
Old Jul 7, 2012 | 02:42 PM
okmac's Avatar
okmac
It could be something as simple as a PVC valve not operating properly. It would cause a rough idle .
Just my .02
Mac
Old Jul 7, 2012 | 10:21 PM
CRUZNC4's Avatar
CRUZNC4
Thanks for the responses. I was texting a buddy today that has a low mile 90 that he's owned for two decades and he said that it could be the IAC valve not functioning. He was having similar issues as mine. He also replaced the computer at the same time and his runs a lot better. I hope this helps.
Old Jul 8, 2012 | 05:06 AM
XR_Strider_GuY's Avatar
XR_Strider_GuY
One fairly straight forward way to check if injectors are leaking is immediately after a drive switch the car off. Pull the intake pipe assembly off the throttle body. Next part I found is easiest to hear in a quiet garage. Manually open the butter fly valve. If you can hear a faint hissing and the smell of petrol through the throttle body, The injectors are leaking. If you hook up a pressure gauge to the shrader valve you will see it will not hold the 38-42psi over 20minutes.
Leaking injectors (albeit if leaking are not severe) will not be too noticeable under cruising and generally doesn't affect the WOT scenario. I find at idle the car feels lumpy as there is minimal air but its dumping more fuel than necessary.
I just found this out yesterday with my 1990, so a new set of injectors are on the list.
Old Jul 8, 2012 | 08:20 AM
Churchkey's Avatar
Churchkey
All good suggestions.
@ 45K it is due for a cap, rotor & wires.
If still using the stock injectors they will fail. Suggest ohm testing them cold & hot.
IIRC the reading should be 14-16 ohms. Wait for someone here to verify the correct reading or a search will yeald the correct #'s. Been 3 years since the Bosch 3's were installed in my 90, it runs as new, not so much as a hic-cup.
Jon @ FIC here on the forum is the man for injectors.
GL
Old Jul 8, 2012 | 09:09 AM
CRUZNC4's Avatar
CRUZNC4
For some reason I'm just not feeling that it could be the injectors or the ignition. The car runs fine without load, but doesn't run under load. Yesterday I did a driveway check and noticed that when the ac is off and in gear the car holds an idle, but when I turned on the ac the car ran rough and stalled. The iac valve is supposed to keep the car from stalling under load changes and mines not. One of my projects down the road is that I'm planning on having some engine parts powdercoated. When I decide to have this done I'm gonna replace the injectors and upgrade the ignition.
Old Jul 8, 2012 | 12:42 PM
okmac's Avatar
okmac
According to my Chilton manual there is an easy way to check to see if your IAC valve is working properly.
Here are their instructions.
Unplug the IAC connector and check the resistance between the IAC terminals. Resistance between terminals A to B and terminals C to D should be 40 to 80 ohms. If resistance is not within specification the IAC valve must be replaced.
Check the resistance between terminls A to C, A to D, B to C and B to D. Resistance should be infinite. If not the IAC valve is faulty.
Regards
Mac
Old Jul 8, 2012 | 06:23 PM
CRUZNC4's Avatar
CRUZNC4
Regards
Mac
I will check this out thank you.
Old Jul 21, 2012 | 09:22 PM
CRUZNC4's Avatar
CRUZNC4
Today I had a buddy from the Corvette club stop by and we replaced the iac valve and cleaned the throttle body, it was carboned up where the iac valve goes. When we put it back together and started her up it was doing the same thing. It was running fine at idle without the ac on and in gear, but ran rough and stalled with ac on and in gear. A short drive said there's some hesitation with the ac off and bogging like crazy with the ac on. Does the iac valve need a learning phase before the computer recognizes it? Could there be something in the ac system that's bogging the car down? Or could the tps or map sensors not functioning?
Old Jul 22, 2012 | 07:38 AM
joe paco's Avatar
joe paco
fsm suggests unhooking tps to see what reaction you get. if it improves, the tps is suspect. yours is not adjustable, I believe. also map sensor, to get a reaction.
these are clues, and may not be your problem. it should set codes for tps and map, 21 and 33. my thought is that ac on is altering fuel delivery, which may be out of balance already, from sensors, even CTS.
Old Jul 22, 2012 | 03:29 PM
RLG's Avatar
RLG
On my 90 I had a slight miss at idle, but ran great under acceleration. Turned out 2 injectors ohmed at 5.6 or less. Replaced injectors and the car ran great. I replaced the IAC for another reason.
Old Jul 23, 2012 | 12:05 AM
BOTY79's Avatar
BOTY79
Just asking for my own but would like any advice just to rule out different things that it might be with reason and ways to check.
1 ECM
2 Cats
3 Fuel filter
4 Head gasket
5 Vacum lines
ROD
Old Jul 23, 2012 | 03:15 AM
Midnight 85's Avatar
Midnight 85
Finalist 2020 C4 of the Year - Modified
1 ECM
2 Cats
3 Fuel filter
4 Head gasket
5 Vacum lines
ROD
1. ECM failure is rare but does happen, it costs more to check an ECM than a new one.
2. If a cat is plugged it will usually choke the engine at higher rpm than idle and exhaust temps are higher between the engine & cat.
3. They're cheap so if there is doubt, change it.
4. A bad head gasket can be detected with a compression test, the engine may have a miss.
5. Vacuum lines, check vacuum with a gauge if it is low or fluctuating a lot then it's time to start inspecting each & every one, inch by inch. I can personally attest to this one.
Old Jul 24, 2012 | 12:35 AM
CRUZNC4's Avatar
CRUZNC4
Over the weekend I had a buddy stop by and did a number of checks. We tested the iac which was changed and the throttle body cleaned, it was ok. We checked the timing and was ok. We checked the fuel psi and the injectors and are good. Thing of it is I found out later Sunday night at a Forum buddy's house that when the spark plugs were replaced a few weeks ago the #2 cylinder plug was not in all the way and was cross-threaded. It was loosing compression there. I'm not ruling out a head gasket since I have been dealing with this hesitation for a while. Now I'm looking into somebody with experience with a threader. My Vette is undrivable and I'm not happy.
To 90 Coupe idle issues
Old Jul 24, 2012 | 03:09 AM
TomP.'s Avatar
TomP.
I have 1990 that had the same problem when i bought it . Tried the usual things plugs and wires . Still N/G then found a thread on this form to check the injectors that was it . Ohm them out cold and hot like was suggested here . I found 3 bad that I replaced ran good for a few days then started acting up again tested hot found 3 more . At that point I said what the hell and replaced them all . The car has run fine for the last two years . That 14 to 16 oms sounds about right to tell if good or bad . My bad read three to four oms .
Old Aug 6, 2012 | 09:04 PM
CRUZNC4's Avatar
CRUZNC4
Default Update!!!!!
After work today I stopped by the shop expecting to get my valve covers to clean and refinish since it was in for all new gaskets since I thought I had a faulty head gasket. The shop owner fixed the #2 plug thread and said the fuel pump was running at half pressure. He also said that the MAP sensor could be an issue. While the Vettes in , it's getting a tune up and fresh coolant. I'll be cruising thks weekend!
Old Aug 8, 2012 | 10:24 PM
XR_Strider_GuY
CRUZN C4,
How is your 1990 running now? Very ironic but I too found that plug 2 was loose and only way to tighten it was to undo the access panel at the wheel well on the right side.
I noted though once the engine is warm and coming to a stop in drive the idle can be just under 500rpm (eyeing the tacho needle) with or without aircon. Feels a touch rough but I am wondering if its just the way the car is. What does yours idle at?
Mine has been going great with new injectors from FIC. A quick drive mix of highway and busy peak hour traffic has shown an average of 20.8 MPG.
