engine cranks but will not run
Old Jul 7, 2012 | 06:18 PM
jmrl98's Avatar
jmrl98
Default engine cranks but will not run
85 vette. Took my USM HSR off as it has been leaking oil since I got from their welds, in order to fix them. Going thru chart A-3A, got spark and the blinking light at injector. Got fuel pressure, but drops to zero in 5-6 minutes. So I call Holley, they say that's about right for the regulator I have. So on to the next page. Test light to circuit 430 of distrib harness, get injector light. Supposedly a bad ignition module. Got the MSD 8366 less than a year ago from Jeg's. Send it back and get a new one. Right, same condition.
Scanned it on attempted start up. IAC at 144 - never saw that before. Inj. pulse width 12.4 - never scanned on start up before, but it was never even close to that when it was running. When I completed the TPS test on chart A-3B (which I did anyway, even though I had a light telling me faulty ignition module), I got a light following the same circuit 430 test mentioned above. That would mean bad TPS. Yet, I hear my IAC resetting when I shut her down - never did that before. Can anyone shed any light on my situation before I throw parts at it?
TIA, John
Old Jul 7, 2012 | 08:48 PM
leesvet's Avatar
leesvet
what regulator?
I have to disagree with the Holley folks...dumping off ALL the fuel pressure that quick means that it was never there OR the pump is bad OR the fuel is bleeding off thru the injectors...none of these events would help it run.
You need 40 psi steady to run right....25 psi just to build a fire in the thing...
when pressure falls off that fast that indicates that it does not have ANY chance of keeping up with a runnin g engine. I'd revisit the FP issue and regulator/pump.
Old Jul 7, 2012 | 10:06 PM
pcolt94's Avatar
pcolt94
Did you ever try a little starting fluid or gas just to see if it will start and run for a couple seconds. I would just like to know for sure the spark is strong enough for combustion. If it does run, then you can focus back on the fuel system with a bit more confidence.
Then might want to pull the injector rails to see if it is spraying.
Old Jul 8, 2012 | 11:15 AM
jmrl98's Avatar
jmrl98
Thanks guys, I'll head in that direction. I have a rail mounted FP gauge, but haven't had anyone observe it while cranking. I get the pump for 2 secs when key turned and the relay click when shut down, and I do have blue spark. The regulator did not pass the fuel system check in the service manual upon initial diagnosis, and that's why I called holley. But like I mentioned the holley guy told me they are meant to bleed down that quick. So I figure it my not operate the same as the stock reg. under the same test. I'll checks some plugs also.
Old Jul 8, 2012 | 02:12 PM
383vett's Avatar
383vett
Originally Posted by leesvet
what regulator?
I'll have to disagree here. The fuel pressure bleeding down in 5 minutes could be a regulator not holding pressure or the fuel pump checkball not holding pressure or a leaking injector. The first two are not necessary fatal and the motor should run fine. I had a pump which would bleed down within 5 seconds of shutdown but had plenty of volume and pressure to power the car.
To engine cranks but will not run
