Changing Distributor
Old Jul 8, 2012 | 08:48 PM
mdsheley's Avatar
mdsheley
8th Gear
Default Changing Distributor
1987, 350, coupe
Hey people,
Any gotchas about changing out the distributor?
Thanks for pointing me in the right direction.
Regards,
Mike
Old Jul 8, 2012 | 10:30 PM
SunCr's Avatar
SunCr
Crank by hand until you've got 0 degrees on the Balancer at the Timing Mark and the rotor is pointing to the #1 cylinder. With a straight edge from the Rotor, mark that on the Intake manifold with a Sharpie. That way you won't have to guess where it goes when you re-install it.
Old Jul 8, 2012 | 10:55 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
After you pull the dist cap:
-mark on intake base where wires come out of dist
-mark on dist base where rotor is pointing
-lift dist until rotor stops turning and mark again on dist base
Before installing new dist, transfer marks from old to new dist; then:
-align dist wires with mark on intake base
-point rotor to 2nd mark on base and work dist gears into cam gears
-with gears fully meshed rotor should be pointing to 1st mark on base
Old Jul 9, 2012 | 06:20 AM
mdsheley's Avatar
mdsheley
8th Gear
Default installing new distributor
Thanks guys, it'll be a couple of weeks from now. I'll keep you posted.
To Changing Distributor
