Low idle when AC turned on
Old Jul 11, 2012 | 10:27 PM
senorv47's Avatar
senorv47
Default Low idle when AC turned on
I have an 88 Corvette and it runs ok except when I turn on the AC. The car idles between 700 - 800 RPM with the air off, but when the air is turned on it drops between 500 - 600 RPM but when it hits 400 it stalls. I suspect an intake leak but is there anything I can do to compensate and keep the ECM happy until I can get the intake leak fixed?
Thanks in advance
Old Jul 12, 2012 | 05:43 AM
ProjectC4's Avatar
ProjectC4
Sounds like the ECM doesn't know you turned on the AC. Before ECM's there was a vacuum diaphragm on the carburator which raised raised the idle when the AC was on. Now I think there's an input to the ECM to tell it the AC is on so the ECM can raise the idle.
Old Jul 12, 2012 | 08:41 AM
senorv47's Avatar
senorv47
Is there a sensor or something that tells the ECM that?
Old Jul 12, 2012 | 08:47 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
ECM does get an AC signal.
Does your cooling fan come on when AC is on ?
The idle air control valve should be open more to allow for the extra load. Is the IAC connected and working ?
Old Jul 12, 2012 | 11:32 AM
SunCr's Avatar
SunCr
HVAC controls simply sends a voltage to the ECM when a/c is requested. You verify/diagnose with a scanner which will show a "Yes" in the a/c field. You will also want to look at Targeted RPM vs Actual RPM, IAC counts and Load Factor.
Old Jul 12, 2012 | 12:15 PM
senorv47's Avatar
senorv47
I will have to check and see if the fan comes on and get back to you. The IAC is connected but not sure whether its working or not. I was going to do the minimum idle adjustment and the tps adjust to make sure both are correct
Old Jul 12, 2012 | 12:17 PM
senorv47's Avatar
senorv47
Default Scanner
Originally Posted by SunCr
HVAC controls simply sends a voltage to the ECM when a/c is requested. You verify/diagnose with a scanner which will show a. "Yes" in the a/c field. You will also want to look at Targeted RPM vs Actual RPM, IAC counts and Load Factor.
Wish I had a scanner but not, so Im going to try some adjustments
Old Jul 13, 2012 | 11:01 AM
senorv47's Avatar
senorv47
Default ac idle
Agent 86, my cooling fan does not come on when I turn on the AC. Should it? I plan on doing the minimum idle adjustment sometime in the next day or so.
Old Jul 13, 2012 | 03:25 PM
AGENT 86's Avatar
AGENT 86
Yes, it should come on when AC head pressure reaches 233 psi.
AC input to ECM comes from HVAC control head. ECM just sees voltage from engaging AC and should adjust IAC to take up the extra load.
Here is some info from my 86 FSM
http://members.shaw.ca/dankai/HVAC%20Electrical.pdf
http://members.shaw.ca/dankai/HVAV'S.pdf
Old Jul 13, 2012 | 09:14 PM
senorv47's Avatar
senorv47
Default minimum idle
Thanks for that information. I started doing the minimum adjustment procedure but I dont think I have the tps adjustment right and Im going to relook it tomorrow. I did however start it up and the idle was about 700 rpm and when I turned on the AC the fan did come on and the idle changed to abot 800. Only thing is that I have service engine light which means it threw a code but I ran out of daylight. I did test drive it and it ran the best it ever has, but when I returned the idle jumped to 1200. I'll get back to it tomorrow.
Old Jul 13, 2012 | 10:14 PM
CRUZNC4's Avatar
CRUZNC4
2022 C4 of the Year Finalist - Unmodified
I'm having similar issues with my 90. I'm leaning on the iac valve. That valve is supposed to keep the engine from stalling under load changes.
Old Jul 14, 2012 | 09:20 AM
senorv47's Avatar
senorv47
I realized over night that prior to my test drive I forgot to plug the MAF back in. I guess it could explain the change in idle. Going to plug it in this morning and dee what happens
Old Jul 15, 2012 | 07:22 PM
senorv47's Avatar
senorv47
Default iac
Well decided to replace the IAC. Part should be in tomorrow and I get to work in the garage. More to follow
Old Jul 23, 2012 | 10:09 AM
senorv47's Avatar
senorv47
UPDATE: Replaced the IAC, did minimum idle adjustment and adjusted the TPI. Cold start was better but still hunting alittle. Once it reached operating temp idle was better when I turned on the AC I can tell the IAC is doing its job but it was still hunting alittle. Can anyone share any additional input on what I should be looking for.
Old Jul 23, 2012 | 02:29 PM
SunCr's Avatar
SunCr
What else can we tell you? A/c request to the ECM so that it can handle the load. See if you can download something to your cell phone to scan it (you can for OBD 2). My guess is that your ECM is toast, but only because that's fairly common when this happens - you could also try an a/c shop, though most only have OBD deuce stuff these days (which is kinda mandatory for modern a/c).
Old Jul 24, 2012 | 06:52 PM
senorv47's Avatar
senorv47
Thanks appreciate the input but the ECM is good. Just having some idle hunting issues. The AC idle is working ok, just have a 100 to 150 rpm idle hunt.
Old Jul 24, 2012 | 09:36 PM
coupeguy2001's Avatar
coupeguy2001
2021 C4 of the Year - Modified Finalist
When my 86 was doing the idle dance,
I unplugged my ignition control modul over by the heater, and forced it to go into limp home mode. I shut it off, then plugged it back in, started it back up, and the hunting was gone.
Sort of like you gotta get them ol electrons moving again..............
Can't explain it, but I was trying anything I could think of, and that worked.
Old Jul 25, 2012 | 09:37 AM
senorv47's Avatar
senorv47
Thanks for the input, but not sure sbout the location of the ignition control module. I will try it and see if that is the issue once located?
To Low idle when AC turned on
