Brakes
Old Jul 12, 2012 | 01:02 PM
shamdave's Avatar
shamdave
Default Brakes
My 1985 is now having a brake issue. A hard pedal and the front tires lock up during milady aggressively stopping. It has good vacuum in the master cylinder and the fluid is OK? Any Ideas do i need a new purporting valve?
any ideas on this?
Old Jul 12, 2012 | 06:18 PM
coupeguy2001's Avatar
coupeguy2001
2021 C4 of the Year - Modified Finalist
you don't have a proportioning valve. you have a 2 stage master cylinder.
Try flushing out the fluid by opening the front wheel bleeders and pouring in fluid from the top.
Don't let it run dry, or you will have to actually bleed the brakes.
When the fluid turns clear on the front bleeders, do the rears.
It sounds like the fluid is contaminated, and the contaminates are in the two stage valve in the master. After all, it is over 25 years old if it is the original.
The real cure is a new master cylinder and four wheel flush with all new fluid.
If you replace the master cylinder, bench bleed it, and then hook up the lines, have someone stand on the pedal, and with light pressure on the pedal, crack the lines and get rid of most of the air. The little bubble that is in each line will find it's way out of the master cylinder once the fluid heats up, and the expansion of the fluid will drive the bubbles back to the reservoir.
Old Jul 12, 2012 | 09:27 PM
Black89Z51's Avatar
Black89Z51
Suckin' gas, haulin' ass.
You don't do the front bleeding first, then the rear. Typically you do RR, LR, RF, RR. Starting from the farthest from the master cylinder working to the closest. I would consult the FSM to make sure you are bleeding in the right order.
I know people have had ABS problems resulting in a hard pedal. I do agree though, try bleeding first. I have suspicions that this will fix the problem though.
Old Jul 13, 2012 | 10:40 AM
shamdave's Avatar
shamdave
thanks gents
Old Jul 14, 2012 | 07:44 AM
Steve Goetsch's Avatar
Steve Goetsch
Pull the anti-lock Brake Fuse, if the brakes are good then you know it is the anti-lock system, I have had the same problem on different vehicles. I just leave the fuse pulled and not have anti-lock.
Old Jul 14, 2012 | 10:19 AM
Silver96ce's Avatar
Silver96ce
'86 is the first year of ABS. He has a '85.
To Brakes
