diff removal?
Old Jul 14, 2012 | 10:13 PM
spartanc4vette's Avatar
spartanc4vette
Default diff removal?
1985 all stock.
any guides on the removal of the diff? and tips to offer?
Old Jul 14, 2012 | 11:18 PM
1fatcat's Avatar
1fatcat
Are you removing the whole differential assembly or just the guts?
Old Jul 15, 2012 | 04:43 PM
Bob1985z51's Avatar
Bob1985z51
Well it's straight forward and simple.
1)jack up the car
2)remove the exhaust
3)remove the leaf spring (some say theirs a special way to do it with a leaf spring compressor but mine just came out)
4) support the tranny on a stand
5)remove the c-beam
6)remove the rest of the rear suspension(toe rods and camber struts)
7) unbolt half shafts/driveshaft
8) jack up the rear end
9) remove the two bolts that are holding the batwing(diff cover) in the car.
10) you might be able to do it your self but me and two buddy's held it as the jack came down.
One thing you might want to do is put some weight in the rear of the car so it doesn't upset the weight on the jack stands. Took me two hours the c-beam is the hardest part. Good luck
Old Jul 15, 2012 | 06:23 PM
spartanc4vette
removing the whole thing
Old Jul 15, 2012 | 08:17 PM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
Since you'll be removing the drive & half shafts consider replacing the u-joints.
Check the dog bone rubbers and shocks too.
Old Jul 15, 2012 | 09:13 PM
spartanc4vette
will do
Old Jul 15, 2012 | 10:04 PM
cumbercr's Avatar
cumbercr
Removing the C beam is no fun. I just pulled mine today to swap the transmission. That thing is in there tighter than a nat's azz.
Old Jul 16, 2012 | 10:02 PM
l98tpi's Avatar
l98tpi
Max G’s
Ther is no reason to remove the c beam. You just remove the bolts where the rear axle connects to the c beam. You can leave the c beam bolted to the trans, just keep it supported. Get all your universals replaced when you have the rear out. Also, make sure you mark your drive shaft rear axle yoke before disassembly or you may be out of balance.
To diff removal?
