Headlight problem
Old Jul 14, 2012 | 11:35 PM
Curveit's Avatar
Curveit
Default Headlight problem
I've got a problem that doesn't seem to be in the Search section. My RH Headlight will go down just fine, but won't go up. I switched Relays, and replaced the Isolator Relay with no change. When I took it apart, one end of each magnet looked weird... is this normal? I'm guessing I need a new Motor. Anyone have any ideas? Thanks.
Old Jul 15, 2012 | 02:24 AM
Cliff Harris's Avatar
Cliff Harris
What year?
If one of the early ones, it's probably a stripped plastic gear. The later ones can also strip the plastic gear, but most often chew up the bushings.
Old Jul 16, 2012 | 01:24 AM
Curveit's Avatar
Curveit
It's a late '86, 3-wire motor. The gears are ok, and it doesn't have bushings.
To Headlight problem
