Remove Battery
Old Jul 17, 2012 | 02:17 PM
c-4guy's Avatar
c-4guy
Default Remove Battery
Needing to put a new battery in my 96, could someone tell me the easiest quickest way to the old one out,,if there is one.. Thanks for any info..
Old Jul 17, 2012 | 03:00 PM
96_vette's Avatar
96_vette
Go and get a torx socket tool set from sears
Remove the side vent cover, watch for the small bolt on the bottom of the panel.
Remove battery terminals
Loosen battery hold down grommet
Slide out battery
Installation is reverse of removal
Which brand battery did you choose to replace it with?
Old Jul 17, 2012 | 03:13 PM
c-4guy's Avatar
c-4guy
Thanks for the quick reply.. I,m not sure what to replace it with , any suggestions? Have been having intermittent starting problems.. some time when i turn the key i get one click,, then if i try again right away it will start perfect.. trying to narrow it down, thinkg it might be the starter, but if I leave the head lights on for about 1 minute it wont start then either until I turn the lights off .. I'm a little confused..
Old Jul 17, 2012 | 03:20 PM
TorchRedlt4man's Avatar
TorchRedlt4man
From: Chicago Executive Airport, formerly known as Palwaukee
No-IL Events Coordinator
St. Jude Donor '12-'13-'14-'15-'16-'17
Read this:
http://www.corvetteactioncenter.com/...o-starter.html
96_vette's Avatar
96_vette
What is your alternator putting out? I had similar symptoms with my 96.
I replaced the alternator, battery and starter. My starter was damaged due to heat soak. Now it starts up fine. Don't just replace replace the battery, you may have a faulty alternator, check to see whats its charging out. Be careful about where you get a starter. I got mine at Autozone, but some have not been lucky with buying a refurb unit. Good luck.
Old Jul 17, 2012 | 03:31 PM
c-4guy's Avatar
c-4guy
the alternator is putting out around 14.5 volts.. I just thought the battery might be going bad when it wouldn't start it after leaving the lights on for a minute with the engine shut off..
Old Jul 17, 2012 | 03:38 PM
c-4guy's Avatar
c-4guy
Does the bottom bolt on the side panel have to be took completly out to get the panel outor can it just be loosened a little?
Old Jul 17, 2012 | 03:41 PM
96_vette's Avatar
96_vette
I always just loosen it enough to slide out the panel.
Old Jul 17, 2012 | 03:42 PM
TorchRedlt4man
Just loosen the bolt at the bottom of the panel. The panel is slotted.
If you are getting a click sometimes and other times the engine starts right away, sounds like an issue with the contacts inside the starter solenoid.
The link in my post above has a lot of pertinent information.
Instructions for replacing the solenoid contacts are on the Nations Auto Electric website.
Have your battery tested. Any of the major parts stores can do this for you for FREE.
Old Jul 17, 2012 | 03:45 PM
92ragtop's Avatar
92ragtop
2019 C4 of Year Finalist (appearance mods)
2015 C4 of Year Finalist
You may need to grind down an old 10mm wrench to make it fit in there, or just make your own wrench from a piece of thin flat bar.
Old Jul 17, 2012 | 03:49 PM
vetteblack's Avatar
vetteblack
My 94 did that a couple weeks ago. I started by seeing if the battery terminals had gotten loose. Turned out thats all it was, maybe its all the wrong with yours too?
Old Jul 17, 2012 | 05:34 PM
c-4guy's Avatar
c-4guy
Thanks for all of the replies and good advice/info.
Old Jul 18, 2012 | 01:57 AM
Cliff Harris's Avatar
Cliff Harris
If you're still looking for a new battery, I recommend reading this article:
http://www.corvetteactioncenter.com/...y_battery.html
I found that the Sears Platinum (it's made by Odyssey) is cheaper and easier to find. The number of Odyssey dealers is limited.
I went to the Sears Platinum after two Optima batteries in a row died an early death. The second one was 11 days past the "two years free replacement" date.
To Remove Battery
