Engine Harness: Manual/Electronic A/C
Old Jul 17, 2012 | 07:14 PM
bolowbc's Avatar
bolowbc
Default Engine Harness: Manual/Electronic A/C
Hey guys,
I found one for sale that is the same year for the same transmission, however it is for electronic instead of manual A/C.
My understanding is that we also have an in-dash harness that hooks up to the sensors and A/C unit in addition to the engine harness.
I would assume that I would be able to have the A/C wires for the new engine harness (electronic A/C) swapped with the wires from my car (manual A/C)? I'm trying to find out if buying the new harness with electronic A/C instead of manual A/C can be made to work, or would be a waste of money.
Thanks,
Will
Old Jul 17, 2012 | 11:53 PM
SunCr's Avatar
SunCr
A/C - Electronic or Manual is part of the Body Harness. If you're just getting the ECM harness, the a/c signal wire should be the same. For Manual a/c, it's spliced into the compressor control circuit and then to the ECM (12 volts). For Electronic, it's a separate Circuit from the Control Panel - 6 volts. ECM recognizes either voltage as an A/C request and increases IAC counts; cuts power (removes ground) at WOT. Fan signal is the same too - separate circuit from the ECM to a normally grounded switch on the High Pressure Line. You'd probably benefit from some schematics including the full body harness which folds out from the rear of the Service Manual through '89..
Old Jul 18, 2012 | 01:41 AM
Cliff Harris's Avatar
Cliff Harris
Interesting timing on this post...
Posting the year of your car will be very helpful.
See this thread:
http://forums.corvetteforum.com/c4-t...some-help.html
To Engine Harness: Manual/Electronic A/C
