****Question for Mikes1991****
Old Jul 20, 2012 | 12:40 AM
Brian Blum's Avatar
Brian Blum
Default ****Question for Mikes1991****
Mike I read your thread on top glass top restore and what you to see these pictures:
The shinny part is just where I used a wet wipe to show how dull it is.
I just bought a used top to put on the car so my fiberglass top can be fixed. The top is dull and is covered in a haze. I knew the top was like this, but if I can fix it cool if not no big deal. Is this what yours looked like before your restore? Also your thread said glass top restore, but this is a plastic top, is that going to make it different?
Old Jul 20, 2012 | 11:41 AM
Kmcoldcars's Avatar
Kmcoldcars
The transparent tops are not glass. They are acrylic, which is what you are calling plastic.
If you have a random orbital buffer get a fine polishing compound and start polishing. If you do not have a random orbital buffer then you can do the buffing by hand with a soft cloth and a hand buffing compound.
If the surface of the top is really scratched and beat up and buffing does not clean it up then you should wet sand with a proper grade of sandpaper, such as 600 with water, and then 1000 and 1500 before buffing.
Have fun.
Old Jul 20, 2012 | 05:27 PM
Brian Blum's Avatar
Brian Blum
I was wondering what the options for clear tops were. I was under the impression the factory clear tops were glass and aftermarket were acrylic. Was there ever a glass top on the C4?
Old Jul 20, 2012 | 05:43 PM
ch@0s's Avatar
ch@0s
GO to your local auto parts store and buy a 3M headlight restore kit. 20$ easy fix.
To ****Question for Mikes1991****
