broken spicer
Old Jul 20, 2012 | 06:12 AM
maverick1453's Avatar
maverick1453
Default broken spicer
I was driving my 93 corvette stock . and noticed when I would change gears. from drive to reverse or neutral to drive or any of these combos. the back right axle area would jolt perty gnarley. and it ran that way for a while. and I just dealt with it
but then the other day i went in reverse from park. and i heard something snap. and clang on the concrete i got out and checked it and noticed a broken cap that said "spicer" was laying there. I believe its a ujoint?
and now my car drives like the back passenger tire is oval hopping all over the place. besides taking it to shop any help here would be much appreciated thanks
Old Jul 20, 2012 | 09:01 AM
aminnich's Avatar
aminnich
Quit driving it before you do more damage. You have a broken half shaft joint and apparently no common sense.
Old Jul 20, 2012 | 10:20 AM
383vett's Avatar
383vett
Why don't you keep driving it until it won't move at all? Then it will be easy to figure out what is broken. Bring a dust pan and a broom along just in case.
Old Jul 20, 2012 | 11:19 AM
WVZR-1's Avatar
WVZR-1
I'd say you're ready for a "roll-back" ride!!
You obviously don't do your own maintenance or you would have looked into the problem long ago! It also doesn't sound like you've the facilities to probably accomplish a repair.
I'd maybe talk to a couple local shops before the "roll-back" ride. It will be difficult and expensive to move it the second time if you're unhappy with what's told you by the first.
Old Jan 23, 2013 | 02:48 AM
maverick1453
lol thanks was a broken u joint and half shaft
amminich ure a a** corvette specialty in riverside said there was no such thing as a
"half shaft joint "
Old Jan 23, 2013 | 03:27 AM
gerardvg's Avatar
gerardvg
You do realize the half shaft keeps the wheel in place....
The damage the half shaft can do to the spindle and control arms not to mention the diff. Remember you will need a wheel alignment, and really check everything thoroughly. You may be lucky but i suspect your half shaft wont be straight anymore remember they are an aluminum tube!!!
You may end up with a vibration after replacing the universal joints, please take care of your vette or sell it and buy a Toyota
Old Jan 23, 2013 | 05:43 AM
C409's Avatar
C409
"half shaft joint "
...... But apparently there is such a thing as a half shaft U-joint ..... Amminich couldn't have said it much better (except to include the U-) ... especially regarding the common sense comment ...........
Old Jan 23, 2013 | 11:16 AM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
X2. I think that the "a**" in this thread identified himself in the very first post!
Old Jan 23, 2013 | 12:23 PM
cv67's Avatar
cv67
St. Jude Donor '05
Google images askhole
These guys are trying to help
Old Jan 23, 2013 | 01:10 PM
383vett's Avatar
383vett
Old Jan 23, 2013 | 01:15 PM
ch@0s's Avatar
ch@0s
There is one everyday now....JEeezzz.
Old Jan 23, 2013 | 01:48 PM
383vett's Avatar
383vett
Gotta hand it to the op though. At least he didn't take it to the track.
Old Jan 23, 2013 | 09:04 PM
RUU's Avatar
RUU
Chances are the half-shaft broke when you continued to drive it with a broken u-joint!
Old Jan 24, 2013 | 11:05 AM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
ROTF!!! That was hilarious!
Old Jan 25, 2013 | 11:57 PM
Just BOB's Avatar
Just BOB
and the first hint of a problem was back in Oct 2010:
http://forums.corvetteforum.com/c4-p...ion-mount.html
well when i shift into gears. its real loud and jerky like u can feel it alot . like if i parallel park everytime i go from reverse to drive its like im almost getting hit by another car
I was wondering "wat" the OP meant when he said "...and I just dealt with it".
"half shaft joint "
Oh hell, you are Tommy Chong aren't you? that explains. the weird. punctuation. smokin' too many of those half shaft joints will fry "ure" brain cells! (guess i'm a @$$ to)
Old Jan 26, 2013 | 04:26 AM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
"half shaft joint "
Owned...
To broken spicer
