Window Issues
Old Jul 23, 2012 | 10:11 PM
shamdave's Avatar
shamdave
Default Window Issues
My window (drivers side) stopped working I had it replaced last year, I also replaced the switch, still nothing. I took it back where i had the window done and they said the motor is good, the switch is good. it is something in between the two.
Any one have any ideas? Does any one have a diagram?
Any help is appreciated
Old Jul 23, 2012 | 11:18 PM
martymcfly's Avatar
martymcfly
Default What year?
Are they the early style with a ribbon, or the later style with the scissor style?
Old Jul 24, 2012 | 12:37 AM
shamdave's Avatar
shamdave
its a 1985 so i think its a sciscor
Old Jul 24, 2012 | 06:10 PM
Steve59's Avatar
Steve59
I believe that the 84-86's (and possibly early 87's) are the ribbon types.
Old Jul 24, 2012 | 06:34 PM
84CFIZ51's Avatar
84CFIZ51
One thing you could check, I had this problem on mine, is my window swipes on the outside were bad alowing water in the door thus letting condensation build up inside the door, creating corrosion on the main connector feeding power to all door components. I only lost my hatch switch and courtesy light. Cleaned connector and all is well.
Old Jul 25, 2012 | 03:57 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
The LH window switch pinout is:
A-Pnk=power from fuse
B-Blk=ground, for up operation
C-Brn=down when power applied
D-Dk BLu=up, when power applied
E-Blk=ground, for down operation
To test the switch connector, pull the switch and on the connector jumper:
A to D and C to E to bring window up
A to C and B to D to bring window down
If that fails, open the door and open the connector to the window motor. Then jumper power & ground directly to the motor connector.
Old Jul 25, 2012 | 09:19 AM
shamdave's Avatar
shamdave
Thanks Gents Ill try it all Thank you
To Window Issues
