1991 C4 automatic transmission shift problems
Anyone have any idea what could be causing this intermittent shift problem, or what to check? I'm assuming the governor gear isnt stripped, since it did shift through the gears a few times, but I haven't pulled it yet to see if the weights are sticking or a spring is gone. Thanks
If you aren't familiar with the car - did you get it to a respected mechanic for a once over first?
Trans fluid - may have a reddish color - sniff the oil off the dipstick.
Did it smell like burnt coffeee? - would be a first clue of future decissions.
Personally - if its not in normal running/driving condition AND I don't know the existing repairable scenario... there's no way those car keys will end up in my pocket.
This picture is for the earlier version with the D-shaped button, but yours should have a rectangular button in the same relative position:
You don't disconnect anything. Push in on the button (right thumb in the picture). The spring is pretty strong, so it takes some effort. I use a large screwdriver. Push the cable housing to the rear (away from the throttle body -- left hand thumb and forefinger in the picture). It will click several times when you do this. Rotate the throttle to the maximum open position. The cable will click several times as it pulls out of the locking mechanism.
The TV cable should be tight and straight when it's adjusted correctly:
I have had the governor fail in my T700 that caused it to be stuck in first gear with no up shifting. The governor can be replaced without removing the transmission.
As far as getting it to a mechanic, I don't really know of any "respected" Corvette mechanics in my area yet so I had it brought straight to my garage on a flat bed so I could spend some time on it myself first and do some research. I am "taking a shot" on this one. I'm guessing the average shop would have told me the trans is fried, and I expected that would be the worst case scenario when I bought it. And I could tell the car sat in a humid area for a few years by the way it looked and smelled, and by the nest under the intake (it was sitting in a barn). Of course, with any used car, there's always risk. At least this way I didn't pay top dollar for a car that had a trans go out a month after I bought it.
What was the nature of the governor failure on your T700? Was it a broken spring, stuck weights, bad gear, or what?
I have done it both ways and you will get a different amount of "clicks" from each method. It says using the gas pedal is the correct method.
My 93 was doing the same thing. Stuck in 1st, I played with it till it would shift up, but when I let off the gas it would come down to idle. Just like yours. I to took my pan off to find sluge, I only have 65,000 miles on it. I cleaned the valve body, new fluid, and it shifts great now. I have made note of what you have done just in case I start haveing the same problem again. Thanks for your update on the governor drive gear. I may check it soon.
Kyle
So here's another update, I hope someone gets something out of it, for what it's worth (of course I welcome input from anyone who actually has real life experience with all this):
After reinstalling my governor with a new blue Sonnex gear, and using silicone sealer/adhesive to glue/seal the cap, I went ahead today (before even test driving it) and purchased a retaining wire for the cover and the correct o-ring. So I am going to pull the cover back off and use the correct o-ring, grease the inside of the gear hole, dip the gear in trans fluid, and re-install everything with the retaining wire (bale?). My thinking is that there is supposed to be a gap of (I think I read somewhere) about .045 between the end of the governor and the inside of the cover, and this square o-ring is probably designed to give you that gap by keeping the cover from going in too far (makes sense, but just guessing). I don't want this thing to get hot and bind up, which would give me that flat spot on the gear again. And the wire will ensure the re-used cap won't pop off ( I noticed it went back on pretty easy) and will give me easier access to get into it if I need to again. I even bought another gear kit (green, like the one I replaced, with thicker gear teeth than the blue one) to keep for back-up. Still don't know why it looks like it stopped moving (or slowed down) though and got gouged by the output shaft??
so I bought a 1984 Corvette for my girlfriend on Valentine's Day last year2013,at the time she didn't have a driver's license so I got to drive it..Needless to say my foot is heavy and I blew the rear and out,
I replaced it using parts from the auto wreckerput it all back together and guess what the transmission doesn't shift from 1st gearI think anyone reading this understands how hard it is to get underneath of these carsI would recommend using jack stands so the wheels are free thanks for the information on the governor I'm about to check it out now I will keep you informed
