4+3 no reverse...What gives?
Old Aug 7, 2012 | 07:05 PM
coupeguy2001's Avatar
coupeguy2001
2021 C4 of the Year - Modified Finalist
Default 4+3 no reverse...What gives?
My 4+3 has overdrive, just does not have reverse. What is the problem?
is it the sprague?
I haven't opened it up yet.
THanks
Old Aug 7, 2012 | 07:55 PM
powerpigz-51's Avatar
powerpigz-51
This is what happened to mine years ago. Consensus was that it was toast, that something (possibly the sprag clutch) spins in the case or something. It was a long time ago, and I got that info off of the site where you could buy the rebuilds and the upgraded parts. That site has since moved...5speed sumthin. com. I ordered me up an 88 off of Ebay and have been running that since. I still have the old one.
Old Aug 8, 2012 | 04:47 AM
rodj's Avatar
rodj
is it the sprague?
Carrier bearing
Carrier Bearing Failure:
The carrier assembly holds the planetary gears in the overdrive. The planetary gear system is what steps up your output shaft speed to give you an overdrive.
In direct mode the planetary gears as a whole are locked to both the input and output shafts of the overdrive.
Since they lock both shafts together with no overdrive the carrier and planets spin together.
When you have overdrive the planetary carrier is locked to the case and is stopped. Power then flows thru the planet gears and steps up your output shaft speed .
So in overdrive mode the bearing is not turning but in direct mode it is. Bearing noise will be heard in direct mode and not in overdrive if the bearing is failing.
Sometimes it can be mistaken for a tire or rear end noise, so pay attention and see if the noise goes away in overdrive.
When a unit gets bad you will also loose reverse.
Assumes of course that the reverse selector lever is working correctly and selecting reverse, check before dismantling O/d unit
Old Aug 8, 2012 | 09:56 AM
coupeguy2001
Well, I found it when I tried to make a u turn at a freeway on ramp, and I couldn'/t back away from the curb to finish turning around. It barely moved with high revs.
When I finished pushing it back, and then got on the freeway, the overdrive worked ok.
I guess I will just have to take it apart and see.
By the way, it was in my pickup truck, I installed my spare trans.
Old Aug 8, 2012 | 09:07 PM
whalepirot's Avatar
whalepirot
Different issues and the biz was sold to a Long Island outfit. Mine was sent to Paul, in Boca Raton for overhaul. Last I checked, the site worked and the new guys I spoke with seemed okay.
http://www.5speeds.com/dne.htm
Read that, but it will refer you to:
http://www.skspeed.com/corvette_transmission.aspx
after a couple clicks, that is.
Old Aug 8, 2012 | 09:26 PM
frank j. moran's Avatar
frank j. moran
Originally Posted by rodj
Carrier bearing
This is exactly the problem. I had 2 units with the same situation. In both instances the front bearing went out and damaged the front adapter plate, also in both cases the thrust washer was chipped and bad. They are not hard to do but be ready to spend around $500 for parts.
To 4+3 no reverse...What gives?
