Muffler experiment......
Old May 30, 2002 | 12:11 AM
joseph p's Avatar
joseph p
Default Muffler experiment......
I've always liked the sound of the '65-'67 Vette sidepipes, which is created by use of a chambered exhaust tube in place of a muffler. I was thinking of taking an LT1 tip and welding it to a piece of 16"-18" chambered exhaust tube and using it in place of the muffler. It probably will be loud, since the tubes on the sidepipes were at least 4 foot long, but it still seems it would be quieter than "muffler eliminators".
Has anyone ever tried this, how did it work out?
Old May 30, 2002 | 12:18 AM
GlockLT4's Avatar
GlockLT4
Default Re: Muffler experiment...... (joseph p)
Good idea. Sounds kinda like cherry bombs :)
Old May 30, 2002 | 01:11 AM
vettl83's Avatar
vettl83
Default Re: Muffler experiment...... (Glock'94)
Look at it this way, if you don't like it you can still purchase one of the chambered exhaust kits. Assuming it's an LT-1 or LT-4 your wrenching on. :cheers:
[Modified by vettl83, 5:12 AM 5/30/2002]
Old May 30, 2002 | 10:43 AM
joseph p's Avatar
joseph p
Default Re: Muffler experiment...... (vettl83)
Actually it's an '89 L98 which is why I was wondering how it would sound. I won't have the dual chambers running down the center like the LT1's, I'll just have these pipes at the end of my stock cat-equipped system in place of the mufflers ( with LT1 tips added ).
Can't believe nobody has tried this???
Old May 30, 2002 | 11:06 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
To get similar sound you need duals and then chambered exhaust.
Otherwise you have 8 cylinders combined and later split into two paths, instead of 4 down two paths from the headers.
It's sort of like combining two stereo channels into a mono and then feeding the mono into two speakers. No matter what the speakers, it won't sound like stereo.
To Muffler experiment......
