Help me Build a motor
Old Aug 12, 2012 | 01:23 PM
RandomTask's Avatar
RandomTask
Default Help me Build a motor
So we took our craptastic 84 to the Chump race at VIR yesterday. As expected, the trans lasted a couple laps before it wouldn't shift into third. We brought it in, flushed the fluid, and sent it back out. For this, the motor overheated and we have a rod knock. So all in all we're ditching the trans and considering the following;
Our criteria: We want at least 200 hp (stock)
1.) Put a four cylinder in it.
Doing this to mostly **** off vette fans. Would cut lots of weight out. Unfortunately, to get a 4 cylinder engine at this power level will be expensive for both the engine and conversion. If we can however, find one cheap, we'll do this. Also be much better on fuel than the 'goes through 6 gallons while on the track for 40 min' stock engine.
2.) Put a V6 in it.
Again, would have to find an adapter as pretty much all GM v6 engines worth a damn have different bolt patterns.
3.) Rebuild the stock motor.
Build it for ~400hp. Would like to use cast cylinder heads (would think one would have to ditch the stock (l83) heads.
Anyone input would be appreciated or any suggestions on build kits that would get us to our power level would also be appreciated.
Cheers,
Old Aug 12, 2012 | 02:02 PM
RandomTask's Avatar
RandomTask
Another option we're exploring is an LM7, thoughts?
Old Aug 12, 2012 | 03:50 PM
tahoemedic's Avatar
tahoemedic
Really depends on your budget. Cast heads are ok but won't flow as well and in a Corvette where space is confined, the cast heads won't cool as well, one of the advantagees to aluminum heads.
I have a 383 stroker in mine and it was dyno tested at the tires, 492hp. You could just go 0.030 over bore, put a good set of heads that have been ported, etc and that will get you to 400 HP easily
Old Aug 13, 2012 | 03:07 PM
Crepitus's Avatar
Crepitus
Track only?
Budget?
Time / work invested?
Does it need to look fairly stock?
This could turn out to be a fun thread.
1; 2pc rms SBC 3.75 bottom kit. valve train and top end.(simple)
2; stock 1pc rms short block with top end and cam.(cheep way to a roller cam)
3; LS1 w/ cam and tune.(easy 400hp aluminum block saves about 80#)
Old Aug 14, 2012 | 04:13 PM
wilcar's Avatar
wilcar
If you want to stay with cast heads I would higly recommend the Summit 152123 large valve heads. They are 72cc with heart shaped chambers and 165 runners, screw in studs, stainless steel 2.02-1.60 valves, .525 springs and are quality heads for $630 shipped to your door and are USA made by Dart. I just installed a set on my 84 carbed Z51 and for the price you cannot do a quality build on an old set of GM performance heads for that kind of money. AFR 190 aluminum heads, a streetable cam, 750 carb, intake would get you to 380 plus hp pretty easy.
Old Aug 14, 2012 | 04:44 PM
TTA579's Avatar
TTA579
My suggestions for your options.
1. 2.0L Turbo Ecotec from a wrecked Solstice GXP or Sky Redline. 200hp, and the cars are about the same size.
2. Grand National/GNX/Turbo Trans Am motor. It's been done before.
3. Drop a crate motor in it.
Old Aug 14, 2012 | 09:51 PM
RandomTask's Avatar
RandomTask
Originally Posted by Crepitus
Track only?
Budget?
Budget- Cheap. Absolute garbage cheap. This chump racing, (www.chumpcar.com)
Time - I'm willing for whatever it takes, already have tons of hours invested (cage, etc).
Appearance - Yes, looking stock would be best.
1.) Not familiar with it, details?
2.) Also sounds about right.
3.) Can't - We're doing chump car. Half the point of it is to cheat. I'm pretty sure they can tell the difference between stock and LS1. Even thought about Vortec, but that's out.
Did you get them flowed? What did you do for a bottom end? Northern makes a stupid cheap rebuild kit;
http://www.northernautoparts.com/Pro...tModelId=18788
Another venue I have, a good friend does late model racing and has tonnnns of spare parts. However, all his motors are built to live at ~6500 rpm w/ a 400 cfm carb. Be kind of hard to pull to the line with a motor that sounds like a saturn five.
1.) Researched, min to get the setup, you're looking at ~4k and hours of dicking with stupid stuff like the variable timing, custom drive shaft, etc. I would LOVE to do it though so If anyone wants to donate a setup, ship it and I'll guinea pig.
2.) Hmm, I will research, that sounds . . . interesting!
Old Aug 14, 2012 | 10:37 PM
MonteHall's Avatar
MonteHall
Cruise-In VII Veteran
St. Donor '03 & '06
diesel vette!
Old Aug 14, 2012 | 10:38 PM
RandomTask's Avatar
RandomTask
Originally Posted by MonteHall
diesel vette!
That sounds like a horribly awesome idea.
Old Aug 14, 2012 | 10:43 PM
MonteHall's Avatar
MonteHall
St. Donor '03 & '06
http://www.youtube.com/watch?v=sAWbD9io6bg
http://www.youtube.com/watch?v=Lw9FTFlSsB0
Old Aug 15, 2012 | 07:53 AM
RandomTask's Avatar
RandomTask
First one is legit, second one I believe is fake (dubbed over). That being said, I think finding a diesel 350 may also be a royal PITA.
Old Aug 15, 2012 | 08:48 AM
JackDidley's Avatar
JackDidley
For cheap, just get a short block from a truck. Do rings and bearings and the cam of your choice. I have a good one in my garage that I put together for almost nothing. You can do it pretty easy. Craigs list is your friend.
Old Aug 15, 2012 | 08:54 AM
wilcar's Avatar
wilcar
I did not flow my Summit heads, my 84 is strictly a street car and I wanted lots of low and mid range and the engine rarely will see 4800 rpm. My C4 only had 68K on it when I bought it and was a 2 owner car that had really good care. The PO used Mobil 1 oil and then engine was clean as a whislte inside with little wear so I left as is.
Old Aug 15, 2012 | 10:32 AM
TTA579's Avatar
TTA579
I'm not sure it would be within your price range, since you've stated "cheap", but it would be a ton of fun.
Old Aug 15, 2012 | 01:45 PM
Ray Quayle's Avatar
Ray Quayle
- 1986 Original Owner -
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Here's one in a C4
Old Aug 15, 2012 | 08:26 PM
93 ragtop's Avatar
93 ragtop
[QUOTE=RandomTask;1581571815]Budget- Cheap. Absolute garbage cheap. This chump racing, (www.chumpcar.com)
Cheap
Reliable
Fast
pick 2
You brought a 28 year old (craptastic) car out to race and expected it to be reliable? Trans went? wonder what maintance was done to that in the past 28 years. Motor went? Again, wonder what maintance had been done in 28 years, not to mention mileage on it.
Old Aug 16, 2012 | 02:08 AM
RandomTask's Avatar
RandomTask
Cheap
Reliable
Fast
pick 2
Read the first paragraph again in the very first post and let me know where I said "I'm pissed our car didn't last the whole race".
Second - Its pretty ignorant to think a 350 small block can't make a reliable and mind boggling 200hp + some for cheap.
So if you want to make a suggestion on how/what to build, I'm all ears. But if you come in to criticize that someone would dare be absolutely budget oriented with a stupid low 'performance benchmark', than this def won't be your thread.
Old Aug 17, 2012 | 07:18 PM
Crepitus's Avatar
Crepitus
cheep n easy; You need a crank kit right.
Cast 383 kit,
ported xfire intake,
the 165cc heads w/ 64cc chambers like wilcar sugested or a pair of ported 113s (58cc lotsa compression) the best springs you can get that match the cam,
something like a LPE 214,
RR pan,
the usual xfire tricks
shift at 5500 max!
An automatic?! There was a thread on a mustang or camaro 5 speed a couple years ago (cheep)
To Help me Build a motor
