Best Replacement Tires?
Old Aug 14, 2012 | 08:41 PM
TorchTarga94's Avatar
TorchTarga94
Originally Posted by Ackman70
Continental ExtremeContact DW.
Exactly. If you want a smooth ride with low noise then this is your tire. Pretty good performer too, very sticky compared to the toyo proxes I had before.
Old Aug 15, 2012 | 07:29 AM
GlennS87's Avatar
GlennS87
I use Vredestein Ultrac Sessanta. I really like them. I have used Dunlop SP8000 and Yokohama AVS in the pas and so far I have the Vred's at the top.
Old Aug 15, 2012 | 03:18 PM
Wathen1955's Avatar
Wathen1955
Originally Posted by ccrvtt
Thanks for all the input. The biggest obstacle to choice seems to be the rear tire size - 285/40 17. There are a lot of choices for 275/40 17. Has anyone tried going down a size? Will this have a noticeable effect on performance/ride/handling etc.? I mean other than the fact that 285's just look so cool.
Yeah I noticed a slight difference in the rear only. My 96 came stock, and I replaced the 285/40/17 with the 275/40/17 BFG's. Excellent tire! The only difference I noticed is the rears tend to break loose from a dead stop easier even with my automatic, but it's slight at best. I really wanted to stay with the 285's but could not find the BFG's in that size any more, but it's nice having all 4 tires and wheels the same size.
Old Aug 16, 2012 | 08:29 AM
boonie c4's Avatar
boonie c4
Me Too!
Old Aug 16, 2012 | 08:32 AM
boonie c4's Avatar
boonie c4
Originally Posted by snowmanmdp
I've got the Nitto 555's on my 95 coupe and love them.
Me Too on my 94!
Old Sep 3, 2012 | 07:07 PM
ccrvtt's Avatar
ccrvtt
Default Got 4 to match
I was finally able to locate 285/40 R17s with the help of Kumho's importer. I now have a matched set of their ASX all-season tires. The difference between these tires and the 17-year-old Goodyears is rather dramatic.
Piece of advice: Don't keep those old tires just because they look cool.
The new ones are much quieter and smoother and the 4-wheel alignment helped a lot. I have driven them in pouring rain with utmost confidence.
I don't know what the policy is on this forum, but I would not hesitate to recommend Tire Discounters in Jeffersonville, IN.
Old Sep 3, 2012 | 07:51 PM
mako41's Avatar
mako41
I also use the Vredestein Ultra Sessantas. They have been an excellent replacement tire for my C4.
Found out about them from the C5 guys on this forum several years ago. They were relatively cheap then, now as more people find out about them the price has gone up though!
Old Sep 4, 2012 | 12:43 AM
leego's Avatar
leego
I had the same problems with the Sumitomo's. I also had two sets of tires and both times they were out of spec. The symptoms were the same-vibrating around 70 mph. Finally, I went to Goodyears F1 GS-D3, problem solved.
Originally Posted by GREGGPENN
If you buy Sumitomo's, be prepared to go for the higher-priced road force balancing. And, the possibility of returning a couple of them for being out of spec.
After two sets and being pissed that there was vibration above 70mph, I had them road-force balanced. Two had imbalances greater than a 35lb rotational force at 60mph!
I didn't do that to my prior set, but felt the same way.
Sent the two back (this time) and got two more. It's finally smooth at 75+mph.
And, it ONLY cost an extra $150 to get it all done. Add that to the price of Sumitomos before you decide to give them a shot.
Or be prepared to own a touring car. (Same as that Ferrari guy who drive 35-55mph) LOL
Old Sep 4, 2012 | 05:05 AM
winkosmosis's Avatar
winkosmosis
What about Kumho Ecsta SPT? A set is only $578 at Tire Rack
Old Sep 4, 2012 | 08:15 AM
ccrvtt's Avatar
ccrvtt
SPTs are softer compound but look like an excellent value for the money. Tire Rack's prices do not include freight which adds about $20-$30 a tire, so you need to compare apples to apples. Mounting & balancing ranges from $20-$25 per tire. Sometimes a retailer will offer a package deal which includes mounting, balancing, & a 4-wheel alignment that beats an internet price when all the costs are figured in.
Old Sep 4, 2012 | 09:36 AM
jeffyc's Avatar
jeffyc
i have Goodyear Eagle F1 GS-D3 on my 91 and they are pricey but worth it they hook up good and handle awsome.
the kumos that i had i always had a hard time hooking up and i always felt like i had a flat tire. i have pulled over on the side of the highway a few times to look for a flat
Old Sep 4, 2012 | 10:16 AM
IAFF alumni's Avatar
IAFF alumni
I replaced my tires with a set of ZR1 spec wheels and Nitto NT05 tires.
This is not a daily driver, does not get driven in the wet, or in the winter, so it was a good choice for me.
