89 brakes... booster problem?
for the past few years however, i've noticed that at a stop light i basically have to floor the pedal (or very close) to keep the car from lurching forward. the brake action feels fine for the most part, havent really had the need to slam on the brakes to try to lock them up or get the ABS to kick in, though i may have just got used to driving it like this...
is this a brake booster problem? maybe a vacuum leak in the booster?
all thoughts and suggestions would be appreciated!
kyle
sort of sounds like an internally bypassing master cylinder in the first movement of travel just before the internal valve "cracks".
The secondary piston has a little valve that limits the rear caliper pressure, and that might be weeping.
Also, try flushing the old fluid out and putting in new brake fluid. Sometimes you get suspended contamination that floats in the fluid and causes transient problems.
Unfortunately, these master cylinders aren't cheap, and the repair kits cost more than rebuilt units.
When was the last time the calipers were bled? water in the fluid will go to the calipers.
I rebuilt my 86 calipers a while back, and the insides looked like I had picked them up off a beach somewhere. all corroded. I ended up changing them.
pedal still doesnt feel right... might be slightly worse than before, but probably not by much...
did a little test drive, if i slam the pedal it will engage the ABS/chirp the tires, just feels off, at least compared to other cars (unfortunately i cant remember what the vette felt like long ago, im only 26)
any ideas? i dont want to throw more money at the problem (probably shouldnt have done the master swap but that eliminates the possible piston seal problem)
Remove the inline vacuum check valve. You should have air flow in only one direction. Towards the engine.
If you have vacuum then plug the vacuum to engine line.
Test drive, does it brake the same. If same then the booster has a leak and is bad.
Good luck.
Does your pedal feel firm (not spongy) it should only have a very small amount of travel and feel fairly hard but not much effort required to stop the vehicle from speed or to keep it stopped even when revving the engine.
The power booster is designed to lessen your input to stop the vehicle, if the booster is faulty leaking air the pedal will feel hard and required a lot of effort to stop the vehicle but no further movement. Note some brake pads with little friction compound can make it hard to stop the car like the booster is not working ..
If you have air in the brake fluid the pedal will feel spongy, however old rubber brake hoses can go soft and give a similar symptom.
If you can feel the brakes start to work with a lot pedal travel and requiring more pedal travel to really start working that may be a power booster pin adjustment to the master cylinder and or a bit of air in the system.
Usually a new master cylinder is bled before fitting to the car.
You can always bleed the brakes with gravity, undo the bleeders and let the fluid drip while topping up the reservoir.
If you feel the pedal slowly go down while waiting at the lights that is usually a symptom of the rubber master cylinder piston not sealing correctly allowing brake fluid to push past it and having the pedal to travel further to the floor to keep the car stopped.
Hope this helps you
) so i cant go check it out prior to my postingthanks a bunch!
Perhaps gravity bleed the brakes to be sure, just remove the brake bleeders let around half the master cylinder reservoir go thru the brakes and replace the bleeders do the front first then back.
If the pedal is still soft then it must be your brake hoses.
Good luck
Spongy feeling is nearly always air in the system or old rubber brake hoses and swelling when pressure is applied.
(and yes i know someone is going to say its going to feel like stepping on a sponge
)More travel before the brakes work but a hard pedal will be the pin between booster and master cylinder
