Timing Mark Question
Old May 30, 2002 | 10:49 AM
joalyons's Avatar
joalyons
Default Timing Mark Question
Ok I am going to set up the timing chain on my ' 88 L-98 at 12:00 crank and 12:00 Cam, but why is this engine different than every other small block since 1955?
CompCams lists cams from 1955 through 1998 in their catalog so I dont think its the cam, is it that the crank changed with the one piece rear seal?
I just want to be sure before I button up my timing chain cover that this is right given that I am using a CompCams cam and timing chain. BTW CompCams says to set it up at 12 crank and 6 cam, but the guy on the phone didnt give me a warm fuzzy feeling that he knew what he was talking about.
Old May 30, 2002 | 11:12 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Default Re: Timing Mark Question (joalyons)
Did you note where the marks were before you pulled the stock timing gears?
One way is to put the balancer at +6deg with #1 int/exh closed and note where the marks are on the gears.
Old May 30, 2002 | 11:41 PM
joalyons's Avatar
joalyons
Thanks for the idea, anyone else have some thoughts on why this is different?
To Timing Mark Question
