New member..great site. I just purchased a 19993 C4. Going through it and fixing any flaws. Rear had a bounce to it when going over dips. I replaced the rear shocks with KYB's. It improved but it is still a little bouncey. I can push on the back of the car with my hand and get a slight bounce.Front end has Bilsteins no bounce at all. Should I check the rear leaf spring for wear or go to a better shock? Thanks
Jim:
I also put new KYB on and have the same results as you. The car drives very nice but I think the Bilsteins are the way to go.
Right now I just use the car on the weekends for a cruise so the KYB are fine for that especially when the road gets crappy.
I will eventually replace with the Bilstein.
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
Four same shocks always!
Would you even consider having two different brands of tires front/rear?!!
How old/miles are the front shocks?! If your not sure replace them as well.
