cam surge
Here is my question, since the purpose of two o2 sensors is for emissions and the cats (using two instead of just one). Why not just use one o2 sensor and split the computer wire (I have heated o2's now) so the computer still thinks there are two but really there is only one.
As I understand it the problem with cam surge in a fuel injected car is the split BLM's. The computer can't react fast enough to the o2 readings because they are jumping all over the place from the cam overlap at lower engine speeds. I can see in my data log's the split BLM's and o2 readings all over the place at lower engine speeds. My car is speed density too, don't know if that is better or not.
I also notice that my 02's are right in the header collector. When I look in the collector at the o2 I can see it can really only get exhaust readings from the two top pipes of the headers, the lower two are so far below the o2 that no wonder the readings are all over the place.
I decided to move the both sensors back to the exhaust pipe about 12" after the collector merges, hopefully this will smooth out the readings it gets in the exhaust.
Any thoughts/ comments are greatly appreciated from those of you who have experience with this, being the perfectionist I am, I want this to go away as much as possible.
How is so difficult to post pix???? Anyway copy and past this address for pix;
1.http://s1113.photobucket.com/albums/...t=IMG_4534.jpg
2.http://s1113.photobucket.com/albums/...t=IMG_4535.jpg
1.
2.
Split BLMs are not the reason for cam surge, not to mention they typically only happen at idle due to reversion in the intake manifold. Nonetheless, a split of 5% or so isn't unusual even on factory stock engines and programming. If you have significant split BLMs while driving, you may have a vacuum or exhaust leak.
Cam surge is a result of duration. If you want to get rid of it, you need to run open loop all the time and fix the VE tables and the timing.
What are your cam spec?
I missed the mention of the hot cam by the OP :o I'd also have the tuner take a look at the VE tables in the area where you are having cam surge. Probably need to lower VE a tad more.
I'm running a larger cam 224/230 605/622 112, and have 0 cam surge even at 1100 rpms. It's all in the tune. My car is a MAF car, but even with speed density it can be done.
How do I set the IAC counts? I have checked the TPS it's right on the money .56 volts.
"The second parameter determining the logging speed is the statistical nature of the combustion process itself. No two combustion events in an engine are identical. Therefore, to get meaningful data, multiple combustion events must be averaged to see the overall effects. If each combustion event is analyzed and recorded, meaningful tuning data can’t be seen in most cases. At 6000 RPM an engine goes through 50 engine cycles per second (a 4-stroke engine cycle requires two rotations per cycle). At a logging speed of 12.5 samples per second this would mean that the resulting data is the average of 4 engine cycles.
The above means that data logging engine data needs to be done at 10-15 samples per second. Anything more creates only more data points which do not contain any additional information, but are harder to analyze."
........... Its not so much as taking timing out as it is to level it or equalize it in all the idle rpm and load ranges ... ie ... the advance should be the same number all around your idle speed zone ... mine is currently at 26 degrees from 400-1200rpm from 32-96Lv8 ........ but I have a LOT more cam than yours .......
http://s1113.photobucket.com/albums/...t=IMG_4512.jpg
http://s1113.photobucket.com/albums/...t=IMG_4511.jpg
How do I find the "commanded idle speed"?
No, I don't have a scanner
Thanks for the reply
