Detecting Vacuum Leaks [MAF Code 33]
Old May 30, 2002 | 02:23 PM
jmr302's Avatar
jmr302
Default Detecting Vacuum Leaks [MAF Code 33]
What methods do you guys use to track them down, assuming you can't hear them?
Old May 30, 2002 | 02:30 PM
Derf's Avatar
Derf
Default Re: Detecting Vacuum Leaks [MAF Code 33] (jmr302)
Just curious, why do you suspect a vacuum leak? Code 33 could be the relays (burnoff & power), the MAF itself or an out dated prom chip. Could also be a vacuum leak. :cheers:
Old May 30, 2002 | 03:26 PM
jmr302's Avatar
jmr302
Default Re: Detecting Vacuum Leaks [MAF Code 33] (Derf)
Well either way I still need to rule out a vacuum leak. I've gone on about my Code 33 in other threads but thought I'd start this topic specifically about finding leaks.
I'm worried that the RTV isn't sealing the manifold very well. I installed the intake last summer when it was very hot n' humid here. RTV can half way setup in 2 minutes in those conditions. It's almost impossible to use. My OD pan is leaking because of this.
Old May 30, 2002 | 07:49 PM
PeteL's Avatar
PeteL
From: And on the fifth day, subpoenas were served to Obama senior staff
I use propane, long hose. But remember, propane sinks and it burns. Dangerous. If there is a spark you could flash the propane, up the hose to the tank.
I move the hose to suspect areas and turn the valve on. You will get a rise or a bog at a vacuum leak. Shut off between attempts or areas and let the propane clear.
Hey, it's safer then starting fluid. :eek:
Old May 31, 2002 | 02:20 AM
kenfusion's Avatar
kenfusion
Carb cleaner works good as well. Have someone watch the tach and spray any suspected areas.
Old May 31, 2002 | 02:26 AM
gbr's Avatar
gbr
Default Re: Detecting Vacuum Leaks [MAF Code 33] (kenfusion)
I have used starting fluid but I have found it unreliable and I scares me spraying that stuff on a hot manifold... :eek:
Old May 31, 2002 | 02:54 AM
Aggravated4life's Avatar
Aggravated4life
Cruise-In II Veteran
I agree....carb cleaner works best for me.Many times I cant hear the vacuum leak and the carb spray always finds it with the change in rpms when doing spot sprays.
It wont ignite either.
Try some gumout carb or TB spray cleaner and it can help track down those pesky vac. leaks.
To Detecting Vacuum Leaks [MAF Code 33]
