Bose noise
Old Aug 18, 2012 | 10:19 PM
1986coupe's Avatar
1986coupe
Default Bose noise
I turned on the delco-bose stereo in my 1986 coupe tonight and a loud, high pitch tone came out of the speakers. I turned it off and tried again but the sound came back. I tried it again later and the same result.
Since the sound was loud I was thinking that it might have something to do with the relay. Perhaps I am wrong.
Any thoughts or suggestions?
Old Aug 19, 2012 | 01:12 AM
tpfarm's Avatar
tpfarm
Sounds like one or more of your amps have given up the ghost. Mine sounded the same, and another time had a loud popping noise coming out of one of them. Alot of forum members have gotten rid of their Bose systems but I like mine so I used Ecklers refurbishing service and was satisfied with them. Try and determine exactly which speaker the noise is coming from and go from there.
Old Aug 19, 2012 | 08:45 AM
pmihaltian's Avatar
pmihaltian
Slingshot
Same thing happened to me a few years back. Turned out to be the Bose relay located center dash panel in back of the info center.
http://www.ecklerscorvette.com/corve...1984-1989.html
Old Aug 19, 2012 | 11:15 AM
1986coupe's Avatar
1986coupe
Thanks.
I am leaning toward the relay because it seemed to come from all directions. It made the noise but no sound from the radio.
I will try the relay first...if it doesn't work then I have a spare relay
Old Aug 19, 2012 | 01:39 PM
Red89'-L98's Avatar
Red89'-L98
FL Events Coordinator
St. Jude Donor'13
Thanks.
Start with the relay if that is not it than you have bad amps which can get expensive.
When my amps went bad I found it cheaper to just replace the whole system myself, but thats me.
To Bose noise
