Car: 1987 with Accel HEI coil on factory distributor
Which one is it? The white one or the pink one?
The coil says "Tach" over the red connector. :confused: But the wiring schematic shows the white as the output, and pink as hot from the ignition. The filter is on the white too.
Re: Tachometer Wire...I'm drawing a blank. (-=Jeff=-)
You're right, I got out there(to the car) and it was obvious. I'm never had instruction in reading schematics and I read it wrong. I asked our Avionics guy at work, and he straigtened everything out.
