Head light door problem - 1990
Old Aug 19, 2012 | 06:17 PM
JerryHL's Avatar
JerryHL
7th Gear
Default Head light door problem - 1990
After the left head light door closes, the door mechanism keeps running for about 30 seconds, making a clicking sound, than stops. Has anyone ran into this problem? Any suggestions?
Thanks, JerryHL
Old Aug 19, 2012 | 08:11 PM
airplane50's Avatar
airplane50
Have you checked the 3 white bushings in the headlight motor? GM used small plastic bushings inside the gears to act as a buffer for vibration and to smooth the operation of the lights. The problem arises when time begins to wear down the bushings, and they eventually disintegrate into a white powder. Here is a link that you can check out.
Read more: http://www.corvettefever.com/howto/33098/#ixzz242ZH7
Old Aug 29, 2012 | 05:55 PM
JerryHL's Avatar
JerryHL
7th Gear
Default Headlight Door Problem
Thanks for your help. I am going to replace the bushings & will let you know if it solves my problem.
JerryHL
To Head light door problem - 1990
