Valve Spring Removal
Old May 30, 2002 | 10:10 PM
STL94LT1's Avatar
STL94LT1
Default Valve Spring Removal
How much air pressure do I need in my cylinders to hold the valves up during valve spring removal ?
Old May 30, 2002 | 10:44 PM
BBA's Avatar
BBA
Default Re: Valve Spring Removal (STL94LT1)
Very little. :D
I don't even use air pressure, I just turn the crank to where both valves are closed for a given cylinder, then pull the rockers and remove the springs. The piston will be close enough to TDC to prevent the valve from falling in.
Old May 31, 2002 | 09:12 PM
STL94LT1's Avatar
STL94LT1
Anyone ?
Old Jun 4, 2002 | 01:27 AM
Jay Axson's Avatar
Jay Axson
Damn good question, I am about to do it too.
What is the normal compression pressure in the cylinder? I suspect we shouldn't go over that. Also keep your hands clear as the engine could rotate quickly when the air is applied. :eek:
Old Jun 4, 2002 | 09:47 AM
STL94LT1's Avatar
STL94LT1
Default Re: Valve Spring Removal (BBA)
Very little. :D
Thanks for the tip BBA, I used your method, it worked great. I started to pressurize the cylinders, but it was too hard getting the air fitting in the sparkplug holes.
To Valve Spring Removal
