ABS help
Old Aug 22, 2012 | 05:39 PM
CREWZIN's Avatar
CREWZIN
Default ABS help
OK, I've tried everything to get my ABS light to shut off. Bosch tester showed all wheel sensors working as well as the pump. I've put a new module in and now I've put a new relay in. Still, the ABS light stays on.
Last thing, and then I give up. The main wiring harness that plugs into the module, there's a double wire with a clip on the end coming from that harness. It isn't attached to anything and I don't see anything it could attach to. The double wire is white and dark green with a white stripe. Can someone tell me where this goes, what it attaches tom if indeed it's supposed to attach to anything.
It's the green and white wires that go to a black clip.
Old Aug 22, 2012 | 07:48 PM
CREWZIN's Avatar
CREWZIN
OK. Found the answer. Called my mechanic friend and he had taken a diode connector off when he was first trouble shooting my ABS system. It's a little clear plastic piece that has a diode attach at the end. He had put it in my center compartment that I didn't even know he did that. Fit like a glove onto the end of the green and white wires.
Only thing is, I started the car with everything connected and the ABS light still stayed on. He had to go but said I should take the negative battery off for awhile, put it all back together and take it for a ride so the ABS would recognize the wheel sensors. Will do that first thing tomorrow.
Old Aug 22, 2012 | 11:43 PM
1986coupe's Avatar
1986coupe
Sometimes all of the electrical components work but the wheel bearings could be the problem. I don't know how to check if the sensors are having problems reading the wheels properly.
To ABS help
