How hot do headers get ??
Old May 31, 2002 | 12:00 AM
YellowC4's Avatar
YellowC4
Default How hot do headers get ??
:confused: :flag
Old May 31, 2002 | 12:04 AM
Nathan Plemons's Avatar
Nathan Plemons
Default Re: How hot do headers get ?? (YellowC4)
Exteremely. Coated ones are a little better, but you still don't want to touch them. Engine paint is typically rated to 500 degrees and it'll burn off of headers in about 1 minute.
Exhaust paint is supposed to be rated for around 1200 degrees.
Old May 31, 2002 | 12:30 AM
vader86's Avatar
vader86
Default Re: How hot do headers get ?? (Nathan Plemons)
reach down next time you open your hood after driving your car and find out :D
Old May 31, 2002 | 01:57 AM
vettl83's Avatar
vettl83
Default Re: How hot do headers get ?? (vader86)
See the diesel boys and install a pyrometer gage for a true reading. Diesel boys hell, I'm sure the rice crowd uses them. They have every gauge known to mankind in their cars. :D
Old May 31, 2002 | 01:59 AM
scorp508's Avatar
scorp508
They get pretty warm, but have no affected my coolant temps yet even though they run right by the oil cooler lines. They are cool to the touch within 20 minutes of being off.
Old May 31, 2002 | 02:48 AM
98NYFINESTVETTE's Avatar
98NYFINESTVETTE
From: 10.70 @ 124mph, Stock Bottom End @ 3620lbs, ECS Racing Team Member. The 1st NMCA LSX Index Rumble World Champion. 2011,12,13 Champion
My EGT will be at 1,350 degrees at the end of the quarter mile. I guess it is safe to say that it will be burning hot.
Old May 31, 2002 | 12:24 PM
ski_dwn_it's Avatar
0ski_dwn_it
Former Vendor
Default Re: How hot do headers get ?? (89NYFINESTVETTE)
You trying to figure out how long you need to leave the cake on for?
Their HOT! But as stated the ceramic ones cool much quicker.
Old May 31, 2002 | 12:58 PM
DINO's Avatar
DINO
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
I went to Cruise-In V with Vetteweiser
Default Re: How hot do headers get ?? (ski_dwn_it)
They get damd hot but like scorp said has no affect on the coolant ,oil or any other fluid...mine are jet coated and on the way to B.G. the hottest I saw my car temp at was 190 ...believe it or not :cool:
Old May 31, 2002 | 01:00 PM
scorp508's Avatar
scorp508
I've seen DINO's headers and the TPiS headers are a tighter fit than mine. His coating makes a very good example of how it helps. :yesnod:
To How hot do headers get ??
