Auto Transmission trouble shifting
So on the drive home, I was paying more attention because at the stop light leaving the place, the RPMs were dropping and making the car stutter. The drive back home felt relatively good. However, the coolant temp was up around 230. I turned on the AC and it dropped between 217-225. I head the electric fan turn on at 229 too. The Oil Temp was between 240-245. The oil pressure was on the middle line when driving. When stopped, the oil pressure would drop to the first line and when the car stuttered, the pressure would drop a little lower than the first line. While driving home at a constant speed, I couldn't see the RPMs drop, but it felt like it may have been dropping a tad bit. Something felt weird, but I couldn't tell if it was in my head.
WHAT IS GOING ON!!!????? PLEASE HELP!!!
...oh yeah. I had some steaming near the firewall when I got home too. I thought I solved that issue when I replaced the loose radiator cap from the reservoir up near the fire wall on the passenger side. I haven't seen the car steam in several weeks Lasted maybe 5 minutes.
Also, it is an Automatic. 1994. I believe it is the electronic shifting version of the 700r4...the 4L60e if I am not mistaken.
This has never happened before...by cooperating, are you saying that it will "fix itself"??? And just double checking, to check the fluid, you should warm up the car and check the fluid while it is running, yes?
Sounds like an opti problem, or maybe cracked opti cap, or something on the order of a mis fire, clogged fuel filter, etc......
I would check codes and then check spark plug wires, etc.
To me, it sounds like that you are losing power, and the ECM is shifting the trans to make up for it.
Well, I am off to the garage to take a look at those things. Thanks.
The "Check Engine/System" light on with engine running means the condition(s) are currently present. If the light is not on during RUN operation, the limits were exceeded at some point in time and the event was recorded in memory, but the reading has since returned to the normal operating range.
It read
C12
1
4
9
A.
1.0
and then it would just stay on "1.0"
What do these mean? No check engine lights are on.
It read
C12
1
4
9
A.
1.0
This may answer your question about codes.
http://tech.corvettecentral.com/2011...trouble-codes/
Mac
Mac
Best article on codes I have seen. Turns out I have a lot more to do to read all the categories!!! Thanks!
