Fuel injectors
Old May 31, 2002 | 01:30 AM
Vette 89's Avatar
Vette 89
Default Fuel injectors
What are the implications of installing 24# injectors into an 89 L98 ?
The only modifications I have done is to port & polish the heads, remove the lumps and bumps from the plenum, gasket match everything and install a KNN air filter. The reason I ask is that I have 2 bad injecters and I can get a set of 8 24# with only 30000 miles for $125 :confused:
Old May 31, 2002 | 01:33 AM
vader86's Avatar
vader86
Default Re: Fuel injectors (Vette 89)
#24s will work fine, the ECM can adjust
