security light
Old Aug 25, 2012 | 06:25 PM
joedirt001's Avatar
joedirt001
Cruising
Default security light
security light comes on and stays on even after starting, hear clicking behind dash above radio, engine running fine,'thanks everybody', the clicking is annoying at low rpm's. help or earplugs?
Old Aug 25, 2012 | 08:48 PM
Cliff Harris's Avatar
Cliff Harris
Push the switches on the hinge pillars and see if it goes off. Could just be a bad or loose switch.
Could be a problem with the anti-theft module or the wiring or connectors.
Old Aug 26, 2012 | 06:43 AM
ProjectC4's Avatar
ProjectC4
My '84 did not click but it did weird things if you locked the doors and the wire to engage the starter solenoid was jumped past all the security and clutch interlocks when I got the car.
The security system was the hatch open light not on, a switch in the rear inside edge of each door and a switch behind each door's lock cylinder. The FSM showed a switch behind each door's handle, like a tamper switch if someone punched out the handle but those were never installed - I don't know if later models had them. Any of the switches can put a ground on the security module, telling it something is open. When you lock the doors with the power lock switch or under certain other circumstances which I don't remember, the system arms and the security light goes out just after you close the door. On mine all the door switches were rotten or corroded. I was able to bring one door switch back to life, the other 3 I replaced. The courtesy light switches in the front pillars were not involved with security. The electrical suppliment to the FSM was very useful.
Old Aug 26, 2012 | 08:22 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
The clicking is the horn relay. Does the horn work ?
The theft deterrent alarm is disarmed by unlocking either door, using the key. Try both doors and see if the light and clicking, go away.
There is a switch at door lock cylinder that sends ground to controller. If the system is armed(using power locks to lock doors) and the switch in door is not working, the controller thinks there has been a break in and activates horn.
To security light
