113 spring upgrade
Old Aug 25, 2012 | 09:11 PM
89L98TPI's Avatar
89L98TPI
Default 113 spring upgrade
I have a 89 Auto stock. My injectors just took a crap so I figured I put my Super Ram and LPE Headers on. I also just got a set of Comp Cams Hi-Tech Stainless RR 1.6 ratio. There are 7/16 stud so I know I need new ARP 7/16 studs PN 134-7103. Not gonna lie when it comes to ordering springs, retainers, guideplates etc. I'm lost. If anyone can help me out here I'd appreciate it especially with some PN. I alsp plan on running the 219 cam eventually and 383 but just wanna get her going again before the season is over here in Indiana. Thanks in advance for any help and replies.
Old Aug 26, 2012 | 11:48 AM
89L98TPI's Avatar
89L98TPI
Anybody?
Old Aug 26, 2012 | 12:58 PM
mcm95403's Avatar
mcm95403
I would just call Comp Cams or whoever you like for valve train parts and ask them.
Old Aug 26, 2012 | 01:56 PM
SunCr's Avatar
SunCr
Current production 113's - used on the ZZ4 Long Block and available individually - use LT4 Springs.
Old Aug 30, 2012 | 05:05 PM
Dyno Don L.'s Avatar
Dyno Don L.
Use the Manley valve springs part #22410 & retainer Part #23652
pressures are 125# seat...340# open @.500 lift
Installed @ 1.750
PS no machine work needed.
Old Aug 30, 2012 | 05:21 PM
Black89Z51's Avatar
Black89Z51
Suckin' gas, haulin' ass.
I used Comp Cams dual springs, but I had to have the heads cut to fit them. Whether you take the heads off or not is going to be a factor. A good machine shop in your area would probably be able to pull exactly what you need off the shelf, or at least be able to have it ordered.
To 113 spring upgrade
