Please help with bad pinging problem in 85
Old May 28, 2013 | 02:57 AM
tunedport85inject's Avatar
tunedport85inject
I have an 85 stock too, i understand that the ESC system retards the timing when a knock is detected by the knock sensor.I also know that ESC system is cecked by ECM per start up,at 90°C and WOT simulating a knock,if the ceck fails a code 43 is set by ECM.recently i 'm having a costant SES recently,it's a 43 code. may be my ESC wrong?or am i having a costant ping?in this case how can i fix this condition?moving up the timing from 6 degrees,were i live we only have 93 octane at the pump or highier octane.I'm running a INNOVATE wide band sensor and gauge and my afr recently is lower than 14,7 at medium throttle,it stays about 13,9-14, and at WOT it's in the low 12s.thanks for the reply
