3 Cams
Old Aug 31, 2012 | 07:09 AM
Roger anderson's Avatar
Roger anderson
Default 3 Cams
All, I'd like your help picking a cam. The car is an 86 auto. Mods include...ported plenum, long tube headers, Edelbrock RPM Aluminum heads, no cats, 1.5 full roller rockers, cut air lid, descreened MAF, 3.07 gears, stock convertor.
Choices...
Comp Cam 260AH-14 212/218 @ .050 .444 .444 lift w/1.5 1500 to 5500
Comp Cam X262H 218/224 @ .050 .464 .470 lift w/1.5 1500 to 5500
Comp Cam 268AH-14 222/226 @ .050 .464 .464 w/1.5 1800 to 5800
Future goals as money allows... large tube runners, after market intake manifold. Maybe a 100hp shot. Planning on a PCM chip mod for changes to date.
Drag strip 1/4 mile 3-4 times a year. Best run to date 13.90 @98mph, mostly drive on weekends to dinner, friends or whatever comes up. Don't mind a rough idle as long as it does'nt effect driveablity or computer. No emission testing in Michigan.
Old Aug 31, 2012 | 08:14 AM
Lemme's Avatar
Lemme
St. Jude Donor '10
This is the one I just put in (XFI 268 HR13):
http://www.compperformancegroupstore...gory_Code=RFHR
Old Aug 31, 2012 | 09:29 AM
Roger anderson
I see that cam is a retro-fit roller w/1.6 rockers, aren't 87's already rollers? Mine is flat tappet. Did it work with your stock chip?
Old Aug 31, 2012 | 09:43 AM
Lemme's Avatar
Lemme
St. Jude Donor '10
Oh yes my 87 was already a roller cam. Sorry about that. Forgot that 86s weren't roller cams.
The stock tune seems to be handling the new combo pretty well. There is a bit of a flat spot around 1700 rpm though. Haven't datalogged it yet to see what the afr and timing is doing. Not missing or knocking though.
Old Aug 31, 2012 | 09:44 AM
cv67's Avatar
cv67
St. Jude Donor '05
Stock converter first choice.
Would have to double check but I believe the Lunati 256 has same @050 duration specs but more lift.
Strong running cam with a TPI, lotsa torque!
Old Aug 31, 2012 | 10:37 AM
383vett's Avatar
383vett
Go with a roller cam and retro roller lifters. Hp to be gained with no negatives (except cost of lifters). You'll be pleased with the performance. Valves will open and shut faster, you won't have to worry about cam break in and camshaft wear, less friction, increased performance.
Old Aug 31, 2012 | 12:43 PM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
My 86e is otherwise stock except the Comp Cam X262H, springs and 1.6 CC roller tip rockers.
That is heads, block, intake, TB ...... yes its been tuned by PCMforLess. (BTW no other mods or valve covers are necessary)
The first thing you'll notice is "why didn't I change the cam years ago"!!!
Exhaust note is powerful and commanding. Not overly thumpy.
Overall power band is very noticeably increased.
I lost 1MPG.
Now she sounds like a CORVETTE should.
Old Sep 1, 2012 | 12:32 AM
856SPEED's Avatar
856SPEED
You want something that makes its peak power around 4-5,000 RPM. The L98 intake configuration does not make power beyond that RPM range.....
Old Sep 2, 2012 | 12:20 AM
stevie1dr's Avatar
stevie1dr
If you want to make some power but still be very streetable try the Comp cam 276HR14, (part #8-305-8) its spec's are 220-230 x 510-510 with a 114 LSA. The 1.6 roller rockers get even more lift. I'm running it in mine with a 2800 stall converter and .3.54 rear gears, along with headers, Lingenfelter super ram, AFR-195 heads, and a beefed up 700R4 auto trans. It really performs between 1800-5800 rpms. I run it locally at an 1/8 mile strip and it is very consistent turning 60 ft 1.8 seconds and 7.9 to 8.0 seconds in the eighth at 87-88 mph. with MT street radials.
It's street manners are beautiful and the mileage livable at 15 in the city and 19 on the highway.
Old Sep 4, 2012 | 06:38 AM
Roger anderson
I lost 1MPG.
I'm leaning toward the X262H cam, I should have went with 1.6 in lieu of the 1.5 rockers when i put the Aluminum heads on.
383 vett...other than the added cost of the roller lifters aren't there other items that need to be addressed when going retro-roller...cam button, timing cover, distributor gear, etc??
Old Sep 4, 2012 | 04:50 PM
1986-z51's Avatar
1986-z51
I am running the comp 260 cam. Stock aluminum heads, long tube headers, ported plentum an intake 307 gears. It has a stock idle,pulls hard to 4800 rpm. 13.65 1/4 mile.
Old Sep 4, 2012 | 05:29 PM
383vett's Avatar
383vett
You've just listed them all. The cam button is not a big deal. Make sure cam endplay is correct. Make sure the cam you select has an iron gear pressed on (most have this) and you should be good to go. Stevie mentioned the Comp Cams 220 230 cam. I was running a similar Crane hydraulic roller cam with a 383 and a SuperRam. The car ran 11 teens in the quarter. My opinion is that this cam would be too stout for your 350 and intake. Willie
To 3 Cams
