Replace O-rings behind water pump?
Old May 31, 2002 | 07:11 PM
GS Ragtop's Avatar
GS Ragtop
From: Michigan in the summer, Florida the rest of the time
St. Jude Donor '08-'09-'11
Default Replace O-rings behind water pump?
This afternoon I picked up a replacement water pump from Dal (lucky me - his shop is only 5 miles from my house :D ). I thought that it would include the shaft o-rings, but it only came with the two gaskets.
Are the o-rings a 'must-do'? I'm planning to put the pump in tonight or tomorrow morning and won't have a GM parts dealership open. :(
How about the gaskets - should they be coated with gasket sealer (type?) or can they go in dry?
Thanks in advance,
Brad
Old May 31, 2002 | 07:12 PM
bogus's Avatar
bogus
Default Re: Replace O-rings behind water pump? (GS Ragtop)
I did'nt replace the o-rings... no leaks, either.
secondly, I used a tack to hold the gaskets on... no sealer...
Old Jun 1, 2002 | 04:56 AM
JasonL's Avatar
JasonL
New o-rings are only needed if the old ones are toast. I didn't need to replace mine.
On the advice of some folks, I used a very light coat of RTV on both sides of the gasket. Permatex Ultra Black, but it probably does not really matter what type of RTV you use. Good luck.
Old Jun 1, 2002 | 09:57 AM
tdock's Avatar
tdock
Make sure to seal the threads on the WP bolts also. Not sure exactly which ones extend into the water jacket, so I just sealed all six.
[Modified by tdock, 7:58 AM 6/1/2002]
Old Jun 2, 2002 | 10:49 AM
GS Ragtop's Avatar
GS Ragtop
Default Re: Replace O-rings behind water pump? (tdock)
Seal the threads with RTV?
Brad
Old Jun 2, 2002 | 02:25 PM
JasonL's Avatar
JasonL
Use teflon thread sealant on the bolts. I believe that's what the factory uses.
To Replace O-rings behind water pump?
