I replaced my intake gasket. While doing so I made a few other mods, cleaned and replaced some perishables (EGR valve ETC.)
While re-assembling, before I got too far, I wanted to check for fuel leals before I put back the runners, plenum, TB, hoses and the other junk back on.
So....fuel lines are attached, cold start injector is in, drivers side runner torqued down and I'm getting no fuel pressure. I DO hear the fuel pump kick in.
It is probably your fuel gauge hose not pushing the needle in on the schrader valve. With the fuel pump running, manually push the needle in carefully to see if pressure exists.
About 1 out of every 3 times, my schrader valve gets all cattywhompus in the bore. ***** sideways and makes a mess after I finally get it recentered.
