Lane drift on the highway
Old Sep 4, 2012 | 07:41 AM
flatbush862's Avatar
flatbush862
Default Lane drift on the highway
I have a 1990 C4 with 62k miles on it. When I change lanes on the highway and go over the joint between the lanes, the front wheels tend to track on the joint slghtly until crossing into the adjacent lane. Other than that the steering is tight but the front wheels sometimes wonder a little when I go over a bump. A little scary when I'm on on the gas!
When I have experienced this before with other vehicles, it has been the upper control arm bushings that require replacement.
Are the upper control arm bushings the most likely culprits or are there other items in the front end that may cause this? Which component would be the best to start with?
Old Sep 4, 2012 | 08:31 AM
AirForceOne!'s Avatar
AirForceOne!
That is scary! There are so many possibilites, I would take it to a good shop and let the pro's diagnose it in person rather than get sight unseen advice!
Old Sep 4, 2012 | 08:46 AM
MotorCity_87_C4's Avatar
MotorCity_87_C4
What size rim front and back? I have 9.5 all around and have heard that can cause the "tracking".
Old Sep 4, 2012 | 10:31 AM
383vett's Avatar
383vett
Jack up the front of the car. Have the steering wheel locked and move the wheels left and right. I bet you have play coming from somewhere; steering rack, tie rods, hubs, etc.
Old Sep 4, 2012 | 11:03 AM
DanZ51's Avatar
DanZ51
Easy enough to visually check suspensions parts. Jack it up. I would first look at tie rod ends for movement both outer and inner (on the rack). Front wheel bearings would be next guess, followed by ball-joints (I'm still on my OE ball joints!). Look at ALL your bushings for anything abnormal. Don't forget the rear too. How's you're alignment?
But keep in mind these cars have some w-i-d-e rubber and on certain roads will feel really quirky.
I used to commute on Rte 2 in Massachusetts. There's an area where a large construction firm exits on to the highway and their heavy equipment has worn deep grooves in the asphalt. A lane change in this area is a frightening, white knuckle experience, as a Vette (even my buddies SS Silverado) will literally LEAP out of the lane into the next
Just the nature of wide tires and our degrading highway infrastructure.
Old Sep 4, 2012 | 11:48 AM
Old Ben's Avatar
Old Ben
2017 C6 of Year Finalist
Might be obvious but have you checked tire pressure? My 92 did it and when checking I found the left front down about 10#s on pressure. Had a slow leak in the tire fixed and have barely notice the tracking since.
Another possibility is that the pavement has been grooved. They have a couple sections of the interstate here in town that are grooved and that is mainly where I have been noticing the tracking lately.
Old Sep 4, 2012 | 02:01 PM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
Best to have the front & rear suspension checked.
Concentrate on the rubber bushings. Worn, oil soaked (soft) and overall condition.
Wide tires have a life of their own on uneven surfaces.
Roads that have been grooved by studded winter tires are the worst when changing lanes.
Water grooves at speed are unnerving as well.
Old Sep 4, 2012 | 04:12 PM
92ragtop's Avatar
92ragtop
2019 C4 of Year Finalist (appearance mods)
2015 C4 of Year Finalist
Another thing that could cause this is worn tires. On my 92 with 275's all around, nearing the end of their life, highway lane changes could get exciting. When I replaced the tires recently, the problem was almost eliminated.
To Lane drift on the highway
