Idle is REAL high....
Old Jun 1, 2002 | 01:56 AM
OrangeC4's Avatar
OrangeC4
Default Idle is REAL high....
My vette is idling at 1200rpm's in Park, and about 1000rpm's in OD and stopped. I usually have a high idle, but not this high. What should I check?
Old Jun 1, 2002 | 02:05 AM
merrick's Avatar
merrick
Default Re: Idle is REAL high.... (OrangeC4)
Make sure the butterflies are closing to the stop. If the butterflies aren't binding, then try cleaning the IAC valve.
Old Jun 1, 2002 | 02:30 AM
OrangeC4's Avatar
OrangeC4
Default Re: Idle is REAL high.... (merrick)
I will check that in the morning and clean it even if it isn't dirty. Thanks. :cheers:
Old Jun 1, 2002 | 03:07 AM
ZAD54's Avatar
ZAD54
I had the same problem after I re-installed my cleaned injectors. I reset my IAC (as the instructions in the tech section shows) and the TPS and that seemed to solve everything. Hope your solution is this easy. :cheers:
Old Jun 1, 2002 | 03:14 AM
RadPolo96's Avatar
RadPolo96
Definately check the IAC, if reseting it doesnt work then take it out and clean it.
Old Jun 1, 2002 | 03:16 AM
HighHopes85's Avatar
HighHopes85
If it happened all the sudden, check to make sure that you don't have a vac leak (like the PCV or the brake booster line).
Old Jun 1, 2002 | 03:30 AM
OrangeC4's Avatar
OrangeC4
Default Re: Idle is REAL high.... (HighHopes85)
I checked all the lines earlier, and didn't see anything.
Old Jun 1, 2002 | 04:44 AM
devilfish's Avatar
devilfish
se what volts you have on TPS on idle. mine whas 1.3volts, witch made my car idle at about 1200rpm.
Old Jun 1, 2002 | 09:34 PM
OrangeC4's Avatar
OrangeC4
I removed the IAC and it was way beyond cleaning, so I just replaced it. But, the idle is still high. After resetting the IAC, and I turned my car off I heard air escaping from the circled tube coming out of the brake booster.
Old Jun 1, 2002 | 10:08 PM
HighHopes85
First, unplug that line and just put your finger over it. See if that lowers the idle.
That check valve can be replaced without replacing the entire booster. Don't know if that is the problem, but maybe.
Old Jun 1, 2002 | 10:35 PM
OrangeC4's Avatar
OrangeC4
That lowered it from 1200, down to 950. I guess that is part of the problem. Thanks for that tip. :cheers:
To Idle is REAL high....
