Keep in mind that IF its low on charge, you got to ask yourself...
where did it go?
DO test pressure FIRST<> !
A plugged system will do the exact same thing. It has a high pressure cut-out so it does not blow up. A clogged orifice tube will make it run...shut down till the pressure drops then try to run again briefly. Adding gas is adding to the problem.
