Difference between pcmforless tune and dyno tune
I don't really understand why there is so much question on this thread. Yes alvin does good work, however I have seen the opposite where the tune was too conservative.. it happens. With my 383 build: 1.6 rockers, new valve train, oil pan to manifold rebuild, xfi 268 cam, 32lb injectors, bigger tb, extensive intake work, LT headers, free flowing exhaust, clutch kit, new fuel pump and filter, afpr, air filter, cut airbox, ported heads, bigger valves, new plugs, new wires, new coil should put me where I am now. If all that work just warranted me 50 whp more than stock then something is seriously wrong with the build/setup. I think based on what I have done proves that the tune I got from pcmforless was extremely conservative. I am sure if I datalogged and sent in my chip Alvin would be able to dial it in for me, I just chose to go a different route.
Before I did my build I was very disappointed in the top end speed at the track. It just seemed to go flat. Eventually (after I finished my build) I found that I had a fuel leak at the tank on the sending fuel line.
So maybe your new fuel pump and regulator did make the big difference.
The hp increase at 5000 rpms looks to be about 75hp. I find that hard to believe especially where the AFR never changed.
The air fuel ratio is exactly the same. Which if his timing was off it wouldnt be burning as efficiently therefore the AFR would be different. When I look at the table, it looks like a 75hp gain at 5000 rpms.
I would try and get some more fuel put in for that 1000 RPM and get it a little fatter. Eventually, the knock is going to break a ring land and that will make you an unhappy camper. I'd rather lose some power for the sake of reliability, but that's not my car, and I'm not telling you what you should do with it. Just a suggestion is all.
What et and mph were you running before the tune? Are you running on drag radials? Here is a link you may find interesting. It makes it easier to compare the drag slips from different days. http://www.dragtimes.com/da-density-...calculator.php
Thanks for the link, very cool.
