NOS bottle placement & fuelpump inquire
NOS bottle question.
-Is it ok to just drill trough the bottom of the cargo compartment to mount the bottle holder.
-Do I have to observe caution with the placement of the bolts/screws.
-Anything that might get in the way for the drill ???
-My plans are to place the bottle on the passanger side rear part of the compartment.
Fuel pump question
-Where do you guys get these Walbros.
-Nobody knows anything here about Walbro, I have asked over her but NO !
-I really need your help on this and what is the product number of the 255 lph (67 gph) Holley
pump that replaces the stocker......
As for the Walbro pump. Use either the GSS307 (std presure) or the GSS340 (high pressure). If your fuel pressure stays below 55psi, then the 307 is probably the right pump for the job. You can get the Mustang kit (with the 340) for $119 from Muscle Motors Performance ( http://www.http://www.musclemotors.com/ ) and the 307 is $10 less I think. That is where I have gotten both of mine from and the Mustang kit works just fine. The pumps are identical, but the contents of the kit are a little different. Since you only need the pump and the fuel sock, it makes no difference.
Here is a much better answer... http://www.racetronix.com/Racetronix...t-GSS307M.html
They are available through ARE and other sponsors of this board.
Jack :cool:
Racetronix
[Modified by Racetronix, 7:13 PM 6/7/2002]
