Big Doggy mod
Old Sep 19, 2012 | 02:00 PM
illenema's Avatar
illenema
Default Big Doggy mod
I have the vette issue with this, Anybody done this mod?
Old Sep 19, 2012 | 02:19 PM
jesredvette's Avatar
jesredvette
What's a "big doggy mod"?
Old Sep 19, 2012 | 03:50 PM
Calderone's Avatar
Calderone
move each rear wheel in by about 1/2 inch to fit 11" s
http://aurora40.dyndns.org/misc/C4%2...%20rearend.pdf
Old Sep 20, 2012 | 02:29 PM
esham's Avatar
esham
I did.
Old Sep 20, 2012 | 02:44 PM
TA's Avatar
TA
Originally Posted by esham
I did.
Did you do your own machine work?
Old Sep 20, 2012 | 02:59 PM
Aardwolf's Avatar
Aardwolf
I'm still confused what the hell this is. Something to do with wider wheels? I have 11" CCW wheels with a 315 Hoosier wet on mine now, that tire is over a foot wide, and it fits without mods.
Old Sep 20, 2012 | 03:21 PM
esham's Avatar
esham
No, I had a machine shop do it.
This mod is done if you want to use OEM ZR1 rear wheels on a 88-96 non ZR1 car without them sticking out too much.
The only reason I did the mod was to use the OEM 90 ZR1 wheels on my 90 car.
If someone doesn't care about using the OEM ZR1 wheels on an 88-96 car then just simply use 11" wheels with the Grand Sport offset and no modification is needed.
Last edited by esham; Jan 10, 2023 at 12:25 PM. Reason: changed from 88-90 to 88-96
Old Sep 20, 2012 | 03:34 PM
Crepitus's Avatar
Crepitus
IIRC early offset cars 84-87 can use 11" w 38mm offset (ZR1 A molds) on all 4 with stock geometry. The "Big Dog" allows the same wheel on a late geometry car. 88-96
Old Sep 20, 2012 | 03:55 PM
Aardwolf's Avatar
Aardwolf
Thanks for clearing things up!
Old Sep 21, 2012 | 12:44 AM
illenema's Avatar
illenema
If someone doesn't care about using the OEM ZR1 wheels on an 88-90 car then just simply use 11" wheels with the Grand Sport offset and no modification is needed.
This is true!
Old Sep 21, 2012 | 07:25 AM
C409's Avatar
C409
..... Just curious ... How much did this cost you ? ..........
Old Sep 21, 2012 | 09:08 AM
esham's Avatar
esham
I did this a few years ago so my memory is a little foggy. The spindles
were used off an 87 and were real cheap. I believe the machine shop charged me close to $100 per hub including making the aluminum spacers and pressing on the ABS rings.
To Big Doggy mod
